Need fuel injector harness
The rats got into the wiring underneath the plenum chamber and chewed wire off to #3  injector connectors. Have taken them off and looked at replacement injector connector. The wiring on the new ones is about 2 gauges less than the orginal wiring. I also pulle a harness from a juncker and the wiring on the connectors is about one gauge less than the orginal.
I know that there is a restitance requirement on the injectors, 11 to 18 ohms I think. My injectors read 11 ohms with a hand held Fluke meter.
A question I would ask is, does the smaller diameter wire on the replacement injectors change the restiance on the whole harness to cause a problem?
Thank you, Jerry
Thank you, Jerry
viavr
02-24-2018 11:20 PM
flitemedic
07-11-2005 05:57 PM
restorit
11-01-2002 06:59 AM
