Oil Change in 2013 Ecoboost
I have always changed the oil in a new vehicle early the first time. This is an old tale about the break in oil. I can't find anything in the manual that says this. It also says to change the oild every 7000 miles. I have never gone over 3300. I use this because it runs 3300, 6600, 10,000, 13300, 16600. 20000. Best for an old mans memory.
What do you guys do with your new Ecoboost. I will use the Ford oil.
I would recommend doing what the manual says.
I honestly used to do 3k oil changes, and thats all fine and well, but i realized that it was a waste of money.
I personally do between 5-7k oil changes on my 5.4l with just shy of 250k on the clock.
My 5.0 mustang gets it at 5k religiously because i get bored with it.
The eboost is nothing special from any other motor when it comes to the lubrication system, it is proned to the same problems with contamination and debris. A good filter will help.
If you use good oil/filter, regular oil changes at 5k would not be an issue.
Oil doesn't actually go bad. It gets dirty and the additive package will break down. And when that happens is based on how much load the engine oil has seen as well as temperature.
Someone will post more info directly answering your question, but i just wanted to let you know that its not an exact science and that its not as big of deal as a lot of people make it out to be.
That's what mine says as well. Additionally, it states that of the oil life monitor fails then default to a 5K change cycle.
So, my questions now are: Does the 2013 manual say to dump at 7K religiously? Or, dump at 7K cycles if the OLM fails?
If any of the above questions are yes answers, will the 2011 / 2012 trucks be affected by the change?
Service Maintenance Details
- Replace climate controlled seat filters, if equipped
- Replace engine air filter
- Perform multi-point inspection
- Inspect and lubricate all non-sealed steering linkage,ball joints,suspension joints,half and drive-shafts and u-joints
- Inspect brake pads/shoes/rotors/drums, brake lines and hoses, and parking brake system
- Inspect complete exhaust system and heat shields
- Inspect cooling system and hoses
- Change engine oil and replace oil filter when indicated on vehicle message center or every 12 months, whichever occurs first
- Rotate and inspect tires; check wheel end play and turning noise
On a side bar it also shows:
Your vehicle is equipped with the Intelligent Oil Life Monitor - a system that uses real-time data to calculate optimal oil change intervals.
Check your vehicle's Message Center and look for the following:
- "ENGINE OIL CHANGE SOON" at 5 percent oil life remaining
- "OIL CHANGE REQUIRED" at 0% oil life remaining
EDIT: Also looked at 2013 manual on line and it states to expect the meter to alert you at 7500 - 10000 miles.
I changed my oil early at 1,000 miles, and I'm glad I did. The factory fill was extremely thin and looked dirty as can be. Dropped in some Mobil 1 Extended Life and it looks much better with 2,300 mi on the new oil. I plan to follow my oil life indicator unless and until I find a reason not to.
The oil life monitor in my Ecoboost has been telling me to change the oil at 9000 miles....which I've done each time. At just over 25,000 miles, I'll soon be at the 27,000 mark for the next change. I've had 0 problems with this truck and it hasn't been at the dealership since the day I brought it home new.
This topic has come up in another thread before...but if you are asking me I would change the FIRST oil change at 200 miles. Yes that's right I did say 200 miles. The reason I will do that is because I want to remove those metal shavings. There is no way I would leave them in my motor for 5,000 miles or more on the first oil change!!
Of course there will be people thinking that is crazy and a waste of money, that the oil filter will remove the metal particles . That's ok because everyone will do what they feel is best with their truck...but with mine an early oil change on the most crucial oil change of them all THE FIRST ONE IMO is well worth the money.
Yes, I did. This isn't the first vehicle I've had with 5W-30, and the factory fill was definitely looking thinner than any I've ever seen. My brother, a Ford Service Tech, agrees that the factory fill usually LOOKS thinner than normal... but can't explain it. We both attribute it to either a "break-in" oil, or possibly a by-product of engine break-in.
