06 5.4 rough idle and fuel smell
According to the owners manual on my 06 the recommended oil viscosity is 5w20 under all conditions. I know the Queensland climate is warm, but Arizona in the US is comparable and that is what Ford recommends. I would assume that would apply regardless of whether you were in Queensland or Tazmania, jetford. From what I understand the oil passages in the heads and valvetrain are too small for heavier viscosty oils to pass through in adequate volume to properly lubricate. The owner manual also states not to use any oil additives. Doing so can void the warranty if there is any warranty left.
Thanks heaps for your input much appreciated we will be trying this tomorrow as we are the Total/Elf Lubricants Importers/Wholesalers for North Qld.
sandymane
20
11-13-2016 07:41 PM
