Special tools/F-250/350/450/550 Super Duty;Excursion-Axle -Differential
This Set includes:
205-420 Remover, Wheel Hub Outer Bearing Cup (10 1/2") Full Floating Axle — Dana : F-250/350/450/550 Super Duty;Excursion : 2004-2011
205-421 Remover, Wheel Hub Inner Bearing Cup (10 1/2") Full Floating Axle — Dana : F-250/350/450/550 Super Duty;Excursion : 2004-2011
205-422 Installer, Wheel Hub Oil Seal (10 1/2") Full Floating Axle — Dana : F-250/350/450/550 Super Duty;Excursion : 2004-2011
205-423 Depth Gauge, Drive Pinion (10 1/2") Rear Drive Axle/Differential — Ford 10.25/-F150;F-250/350/450/550 Super Duty;Excursion
205-424 Installer, RH Differential Carrier Oil Seal (Dana 50) Front Drive Axle/Differential : Excursion : 2004-2005;F-250/350/450/550 Super Duty : 2004
205-425 Installer, LH Differential Carrier Oil Seal (Dana 50) Front Drive Axle/Differential : Excursion : 2004-2005;F-250/350/450/550 Super Duty : 2004
205-426 Installer, RH Differential Carrier Oil Seal (Dana 60) Front Drive Axle/Differential : Excursion : 2004-2005;F-250/350/450/550 Super Duty : 2004-2011
205-427 Installer, LH Differential Carrier Oil Seal (Dana 60) Front Drive Axle/Differential : Excursion :2004-2005;F-250/350/450/550 Super Duty : 2004-2011
205-428 Spreader Bar, Oil Seal Front Drive Axle/Differential : Excursion :2004-2005;F-250/350/450/550 Super Duty : 2004-2011
205-429 Installer, Wheel Knuckle Oil Seal Front Drive Axle/Differential : /Front Suspension(2WD) — Four Wheel Drive (4WD) :Excursion : F-250/350/450/550 Super Duty : 2004
$245.00 FOR ALL or best offer- "No reasonable offer will be refused!"
Please Call Ray at 512-845-4844 or raybx01@gmail.com
We accept Credit Cards ( Visa, Master Card, AMEX) -reference available upon request.
Specialtools
Vendor Specials, Discounts, Product Announcements & Group Buys
07-06-2016 09:44 AM
