Water pump is going...have some q's for replacement
1988 F-150 ext cab, short box. 302/AOD.
Okay, I noticed cooling beginning to leak a considerable amount from the front of the ride...it isn't the hoses as they are all new (even the ones that go to the TB) and also a new 4 core radiator w/ cap.
So...I figure at about 105K my OE water pump is beginning to go. I was looking at a high flow replacment:
Flow Kooler - no. 1660
Milodon - no. 16233
Does anyone run one of these? With a 180* thermostat? With the additional flow, would it be smarter to stick with a 195* thermostat? Any problems?
Thanks!
Milodon - no. 16233
Thanks!
I'm running the Flow Kooler 1660 in my '93 Mustang GT 5.0, and have been very happy with it. It's been in there about two years now and I haven't had any problems with it. I noticed a drop in temps by putting it in too, even with the underdrive pulleys I installed when I changed the water pump.
Brian
Brian
You can get a Ford pump from Diversified for $42 +s/h - Part #M-8501-C50. I think mine was $51 to my door.
That pump is more for a Mustang, but fits our truck 5.0 either with a slight modification to the backing plate, or reusing the backing plate from the stock pump. I put one on my '90 (5.0) back before T'Giving, and haven't had a bit of trouble out of it.
Wade
Wade
