General Diesel Discussion
PSP in a gas burner?
Old 12-04-2012, 08:14 PM
BarnieTrk's Avatar
BarnieTrk
BarnieTrk is offline
Say Fellas,
Has anyone tried using Power Service Products Diesel Fuel Supplement (#1025-12) in their gasoline engines as a fuel treatment additive?
After reading their claims, it seems like it would act like Sta-bil, clean the gasoline lines/system, lube the carb/injectors, etc. .....and it would be less expensive (per ounce) than say LUCAS Upper Cylinder Lubricant / Fuel Treatment.
Diesel Fuel Supplement® +Cetane Boost®-32oz Bottle 1025-12
BarnieTrk
Old 12-06-2012, 06:07 PM
therifleman556's Avatar
therifleman556
therifleman556 is offline
Why not Seafoam? Or Sta-Bil? PS is designed for the high pressure and often complex diesel injectors and pumps. Gassers have a simple fuel pump and low pressure injectors that need to be kept clean so a simple solvent would do. Diesels need clean and extra lubrication. I have heard of old timers running a gallon or two diesel per tank of gas and vice versa, though I'd be a little weary of puting gas in a diesel.
Old 12-08-2012, 07:41 AM
BarnieTrk's Avatar
BarnieTrk
Adam, thanks for your response!
I understand that Seafoam or Sta-Bil is made for gas and is a well-known additive. I have run a diesel and I used PSP in it and I think the PSP improved its performance. So, it seems to me since PSP seems to do a good job of cleaning high pressure diesel injectors, it will also clean a carb system or low pressure gasoline injectors too.
Do you think PSP would help keep a gas-powered vehicles running clean - or - could it hurt them?
Thanks! - BarnieTrk
Old 12-08-2012, 09:56 AM
therifleman556
As far as I know, and someone may correct me on this; gassers require more in the way of cleaning varnish and carbon out of their systems which would require more of a solvent action like seafoam. Unless Dieselkleen has an adequate solvent to do this I really see no real world benefit since it is more of a lubricant. I guess one could try it. In that concentration I don't think it would hurt. If you do try it, let us know how it works for you!
Old 12-10-2012, 07:59 PM
nitrogen's Avatar
nitrogen
nitrogen is offline
try archoil. it has made both my diesel and my gassers run better. It also claims to be a combustion enhancer. my bike was badly in need of a carb clean and tuneup. would barely start at 40oF added archoil and fired up real nice. filled up tank without additive and 30 seconds later it was running sickly again.
Old 12-14-2012, 08:33 PM
BarnieTrk's Avatar
BarnieTrk
Thanks for your opinions, Fellas!
I have a couple jugs of the PSP, but I don't know if I'll dump some in my wife's taurus or my ole' 390....
Archoil....Hmmm,,, I never heard of that.
BarnieTrk
02-7.3l-toy
19
01-28-2010 12:01 PM
ramrod7373
15
04-18-2008 04:15 PM
vellomike
Bio-diesel, Propane & Alternative Diesel Engine Fuels
07-24-2006 07:48 AM
Crkside442
08-10-2004 12:48 AM
gokeipow
1997 - 2003 F150
06-25-2004 08:25 AM
Quick Reply: PSP in a gas burner?
