fuel tank
fuel tank
i have a 1994 f350 crew cab truck with the duel tanks. the front one does not work which i heard is common. my question is should i remove it to save a lil weight or replace the fuel pump? and iv read about larger tanks that replace both of them where can i find those at? and are they worth it?
Tank has to come down to replace the tank, so check for rust holes.
I would replace the pump, it's nice having an extra 19 gals.
The rear tank can be replaced with one from a Bronco. That will give you a 38 gal tank instead of a 19 gal tank. You will need also, the Bronco pump, Bronco fuel sending unit, and Bronco tank mount
You will not be able to hang your spare tire back under the truck with the Bronco tank
TallPaul
08-21-2008 11:34 AM
fordtbird1995
05-11-2007 08:48 AM
oldhalftons
04-12-2005 10:33 PM
