Hill Descent/Advance Trac error messages
New Guy here.
I've had some errors show up multiple times since getting my new 2012 F-250 a couple of months ago: "Hill Descent Control Fault," or "Service Advance Trac."
Took it to the dealer two or three times and they replaced a couple of modules: one related to the RCM (whatever that is) , and one related to the ABS system.
Just got the messages again at a dead stop just after starting up.
I saw a thread here from last month about this same issue but no resolution was posted.
Does anyone have any ideas I can give the service techs when I take it back to the dealer next week?
Thanks!
Ed
PS, 2012, 6.7 L PowerStroke Diesel, Lariat Ultimate pkg, 4x4; only mod is a 50 gal extended range fuel tank.
Thanks!
Ed
You will sometimes get that error if you've been driving on loose gravel, sand, etc for an extended amount of time. The system tries to keep wheel spin under control but can't so it just gives up. If you're not and they've replaced several modules already perhaps the problem is with one or more of the wheel sensors. I think they use standard Halls effect sensors and tone rings at the hubs. I'd check to make sure the sensors are seated and clean. I'd also make sure the tone rings don't have anything packed into them which will impact the sensors ability to read the speed which will then send conflicting signals to the PCM.
Just joined site. This thread is very interesting to me. I just traded my 2004 F350 for a 2014 F350. For a short while, I thought I really had something special. The wife and I went on our first trip with it and found ourselves stranded a few times. Would get a cascade of trouble codes regarding AdvanceTrac, Hill Descent Fault, Engine Overheat, Oil Pressure, ABS Brake, etc. It was when it first started at first - when I was shifting into gear. When it would occur, it would keep running but would would not shift into gear (lights dark). Later during the trip, it happened while I was driving. All the gauges would lay flat (except for fuel gauge) but I was able to keep driving after hitting OK for each trouble message. The air conditioning also quit working. Albeit the fan would still blow but the compressor was not cooling. Every time I would stop and let it sit, everything would eventually start working again; and the check engine light would be on. After a few successful starts, it too would clear out (until the next poltergeist visit). It was the trip from hell. It has now been at the dealer for 2 days and they cannot figure it out. The tech says he has been on the phone with Ford but is getting no help. No one can give an explanation for the onslaught of all those codes at one time and then it operates fine the next time. They're talking about letting me pick it up and driving it until there is an all out failure. I guess that means when it leaves me on the side of the road and it has to be towed. I'm catching a boatload of crap from mama bear for spending about $50K on a truck that's unreliable and ditching one that never stranded us and was paid for. Can anyone actually fix what they make anymore? Any suggestions, previous experience, etc. that might help?
Broken wire
I had similar error messages including ABS light. Turned out to be a broken wire pair (yellow and black) going to the drivers side front brake. The break occurred at a plug connection located along the left frame beam across from the oil pan. Wires were broken close to the plug, so I got a replacement female end from NAPA and soldered it on. No errors, no hits, no runs.
