F-350 Axle Vent Hose Routing
On my 95 350, I have found that the rear axle vent hose isn't clipped to the frame or body and has just been routed out of the way. There appears to still be a clip on the line for mounting it, though. It is also capped by what looks like a vacuum hose Y-fitting.
1. Where exactly is the axle vent hose supposed to be clipped to?
2. What should the vent end of the hose terminate in?
Pictures would be appreciated, thanks.
Received 3,186 Likes
on
Venting...
The distal end of the axle vent hose on this model should be clipped up on the bottom lip of the frame rail on the driver side. If you have installed a lift kit the original hose may be too short and pull away. Given the age, you may want to replace it anyway; the original has probably dried/cracked.
dn.
dn.
dn.
dn.
Shortbox4x4
09-06-2017 06:20 AM
littlefoot
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
07-10-2008 05:47 PM
bcsbadboys
07-30-2002 03:17 PM
