No fuel to carb. Fuse location to fuel pump?
Old 11-23-2012, 09:57 PM
Millertyme's Avatar
Millertyme
Millertyme is offline
I have 85 econoline 350 motorhome. She just wont start cuz im not getting fuel to carb. Does anyone know where a fuse would be located or what other options I should look for to solve this problem?
Old 11-23-2012, 10:02 PM
Galendor's Avatar
Galendor
Galendor is offline
If you have electric fuel pump control, then the fuse should be a 15 AMP (light blue), 2nd one below the turn signal flasher on the drivers side.
Old 11-23-2012, 10:09 PM
Millertyme's Avatar
Millertyme
I couldnt seem to find a fuse for the fuel pump so I figured there was a second fuse box. I finally located the flasher but it is hanging off by its self and not in a box? Very frustrated!
Old 11-23-2012, 10:12 PM
Galendor's Avatar
Galendor
Galendor is offline
Go ahead and tell us what engine you have. That will help in the troubleshooting.
Old 11-23-2012, 10:21 PM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
most carb models used a mechanical fuel pump bolted to the side of the engine in the front, exact location depends on which engine you have. its pretty easy to replace, just a couple mounting bolts and a couple fuel lines
rmh1999
06-02-2023 11:40 PM
ok cowboy
02-14-2009 09:38 PM
NS F250
25
03-29-2008 06:38 PM
dansV10
Modular V10 (6.8l)
08-16-2005 09:28 PM
skohler
03-04-2005 09:18 AM
Quick Reply: No fuel to carb. Fuse location to fuel pump?
