Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Lightning Rearend 9.75 HELP!!!
Old 11-20-2012, 01:15 PM
tOSU Lightning's Avatar
tOSU Lightning
tOSU Lightning is offline
My '04 Lightning was in an accident and the rearend is damaged.
Where can i get a 9.75 lightning rear end?
Do all 1997-2004 heritage 9.75 rear ends have the same shock mounts?
Are there any other f150s with stock sway bar mounts?
If not, can i use the sway bar mounts off of the damaged rearend and weld them to a normal f150 rear?
Old 11-22-2012, 08:32 AM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
If you are handy go for it ? Grind, sand, clean it good, U want a tru surface to mount to, no rock-N, a little heat and MIG it for sure. N on cherry red glow of the items.
Old 12-02-2012, 03:15 AM
stoffer's Avatar
stoffer
stoffer is offline
only the Lightings have the rear sway bar mounting tabs, but you can transfer 'em over to a "normal F-150" 9.75
trekbasso
1999 to 2016 Super Duty
03-08-2012 08:12 PM
Bootlegger's Deluxe
03-03-2011 07:31 PM
learpilot
09-11-2006 02:23 PM
GreatNorthWoods
05-22-2005 09:20 PM
Quick Reply: Lightning Rearend 9.75 HELP!!!
