Eaton 2-spd rear end - any value?
Not worth a whole lot, probably not worth the trouble of taking it out unless you think YOU might have a use for it sometime. One of those things that has little to no value unless you happen to find someone close by that really needs one.
If the shift motor/mechanism works it would probably be worth spending the 5minutes to pull that off and sell it. They fail a lot and would be easy to sell online.
Thanks for the info, kinda what I expected. I know this truck hasn't moved in 10 or so years ad no idea if the 2 spd fiunctioned then. It's been neglected on the back of Mikes property for that long. Looks like a little scrap weight to me.
Thanks again for the update/education.
49T&C
49T&C
As much as I would Like to have a two speed rear end there is no way I could drive 1100 miles and justify the expence.... Thanks for your timely response. I hope we can do bussines in the futhure...... randowe@sbcglobal.net
lit420now
12-10-2006 05:01 PM
tendicott
05-21-2000 05:24 AM
