Nik's 97 350 build thread
#32
#33
I don't think you have an issue with injector cups either. That generally results in having fuel in the coolant. I think you're burning the oil. The major places that could account for this are injector o-rings, the injectors themselves, or the turbo. If the turbo has blown the seals, it can use A LOT of oil in a hurry. Typically you see blue smoke from the oil being burned slowly but not burning completely. If you're not seeing a lot of smoke, I would venture to guess that you're putting the oil through the combustion process inside the engine and just using it up. If you're not seeing discoloration in the fuel or filter, I am guessing your o-rings are okay.
Here is what I would do.
-Check the oil level when you're on flat ground and see what you come up with.
-Do the oil cap blowby test (I think you'll be fine)
-Pull the downpipe loose from the turbo so you can pull it back far enough to peer inside. If the turbo is blowing the oil out, you will know it right away when you look inside the DP. It will be all oily.
If all that checks out, then I am guessing that you have an injector or two that has bit the dust and is allowing the oil to bypass the intensifier piston and go into the combustion chamber. This would kind of make sense, if you think about it. If two of the injectors were bad, how far behind do you thin the other 6 were?
You're not running any kind of oil additive are you? Just straight (diesel rated) oil?
#34
I'll check and see what the coolant looks like but am doubting this is the issue as well. I will still check.
When I top it off I'll do the blowby test but I am guessing its fine as well... I do notice my ccv mod that vents to atmosphere I can smell a little bit of fresh oil on start up in the mornings...I have very sensitive smell and with the window down I can smell it...vents right under my door. Very little pressure coming from the hose though...
I'm pretty sure from multiple issues I have had with this truck that its the injectors... I know I need to get them done ASAP I was hoping to buy myself some time till January... But that may no longer be an option!
I really do appreciate your help! Thank you for the comments and advice!
#35
Sure thing man! I hope it is something simple. Injectors wouldn't be all bad. It would just push you to do that mod a little out of turn. I know that right before the holidays is not the time when most people want to make an expenditure like that, but like you said, it may be time. I guess you know what you'll be getting fro Christmas if that's the issue!
#36
#38
Well anytime I can get back at the gov it is winning...thanks for pointing that out... I feel much better about the situation...
Headed to the store here in 15 and then to the mechanic. Hopefully all goes well.
#43
That is what I understood. Its not a bad idea to have a manifold and post turbo/downpipe probe. Manifold is accurate on motor temp, and downpipe is indicative of when the turbo is cooled down sufficiently. .
#44
Once again we did a compression test and the numbers were top notch on all 8... no pressure escaping from the VC and that is what I was most worried about.
I havn't had any problem so far but am in need of injectors to rid the sticking issue. I want to go bigger anyways before i get tunes reburned. I have my boss' truck to do in two weeks and then hopefully onto mine in the future.
I'm a weirdo... After reading previous EGT threads and the difference between manifold and turbo temps I decided to have one in both manifold and post turbo to campare temps and to keep an eye on each bank of injectors. Recently saw a guy have to replace a motor due to a failed injector ruining #4 and melting down...in turn toasting the motor... so I figure why not just throw another pyro in there to watch the passenger side bank as well, especially once I get new sticks...
Its just caution that's all... overkill i know, but I will def say the post turbo and and at manifold temp differences I have seen in all my tunes over the past few months are not anything close to what I have read on here... these are 3 identicle pyros by Autometer...no brand variance either.
Just thought I'd add a third in the passenger bank.
Agreed 100%. I like comparing the different readings under different circumstances, and towing conditions...keep a log book of it, and hope some day I can write up an extensive thread about the differences I saw.
