Installing wireless air bag controller
What is the easiest way to tap into a keyed 12V supply for a wireless air bag controll system? If I use the inside cab fuse box I have to get the wire inside the cab and then the fuse box cover may not fit back on. Isn't there a keyed 12V wire in the trailer harness I could tap into?
Would this be the preferred method?
Thanks in advance for any help.
Love the forum it helped me on the purchase of my 2012 F-350 Crew cab Dually "King Ranch"
I just installed a wireless compressor system and used a fuse tap on the rear window defogger fuse in the under-hood fuse box. It is a switched fuse. I was able to run the wire out of the fuse box with minimal modification to the cover because there is quite a bit of room under it.
I found that the fuses in the cab fuse box are low profile so they aren't good for using fuse taps.
