Aerostar video walk threw
I saw both videos and noticed your RABS proportioning valve has a black connector between the two top brake lines. My '97 does not have that connector, only a 3/4" bolt screwed into the center hole where the connector would connect to a sensor. And yes my RABS light is ON all the time. I've followed all the troubleshooting Service Manual steps including the Code from the diagnostic wire/flashing light. Got a code 12, "low brake fluid level" which is not.
Check your master cylinder inside. See if the float is sticking or stuck down. It can also be bad float sensor or the wiring that comes out has a short or bad ground back to the Ab s monitor under the ash tray.
I might add your just need the upper plastic part with the sensor in it. cheap part from yard and was used in many new trucks still. Might get one and see if goes away.
Do you have the factory service wiring manual? If not I'll see if I can post it, some others can dl it.
Your not going to, the sensor is part of brakes resevior when you buy it. all you can check is the pins on both ends and make they are straight and make good contact. You can check them with an ohm meter. check each one in pairs 1 2, 2 3 and 1 3, see what it is when the float is up then down. I bet the float is bad in the resevior on top of the master cylinder.
ok thank you, I already tried checking the float but it "appears" it might be stuck at the bottom of the reservoir, (doesn't move up or down), otherwise I have no clue what I'm looking for. Is the float located in the front or the rear of the two inner compartments of the MC ?
geez, something so simple and I can't figure it. Sorry but I've never messed with this RABS business before or even an Aerostar MC, my 1992 Aerostar had RABS and it never gave me any issues.
ok, that tells me it's stuck down, there is absolutely no round float to be seen when I remove the cap on the reservoir, nothing I can push down and returns up. Going to check again in the morning. Many thanks.
BTW: I had already checked the wiring at the connector per the service manual troubleshooting steps, and it came out ok, also cleaned the contacts at both male and female connectors, but the light stayed on. It must be the float.
I have no float, zero, nada, no post either, I stuck my finger in there, I tried a pick tool, nada. nothing, I can feel a rounded "base" at the bottom, in other words, a concave base as if the ball would "sit" on it, otherwise no ball anywhere.
is the plastic reservoir available by itself with the float? or do I have to replace the entire master cylinder?
Just the resevior not the master cylinder. The sensor is in it. if you get a used one check the wiring connection pins make sure none are bent or dirty and used dielectric grease. I might post a video on that as well. It rained here so I have not done the new alternator rebuild. I want to paint it with rm paint and clear coat it. still waiting for them mix it for me. They put it in pressure can so I dont need a paint gun, pretty neet with factory matched paint in it.
I found that clearcoat from cans don't last very long. After just a few months of the sun beating down on it, it starts to haze up, and a few more months, it starts to flake off. Then you have to scrape it all off and repaint. You may not have this problem with an alternator that seldom sees the sun, but engine heat may cook off the clearcoat as well. Maybe CC rated for engines will last longer.
While the 1997 Aero service manual shows this type of master cylinder, with the float directly under the cap . . .
(click on images for larger)
. . . our later Aeros don't have the cap over the float:
I'm guessing that Ford is showing a Ranger master cylinder in that pic. It does go on to say:
[later]
This is an odd system. Hmmm. Note this warning in the FSM:
IOW, you could have a failed diode causing your spurious Code 12. It says, "Diode/resistor element located three inches left of the cluster connector takeouts in the instrument panel wiring harness." Not fun. Every time I have to pull my cluster, I pine for my old '89 Aero, where something like six screws retained the dash panel over the top of the cluster, making changing bulbs or whatnot a ten-minute operation, with no danger of breaking plastic/steel retaining clips!
Electrically:
Incidentally, I don't find the Pressure Differential Warning Switch to which that diagram refers (connector C164). The connector reference says it's under the master cylinder, but I just braved the 26° cold with a flashlight, and I sure don't see either that connector or any switch on the Combination Valve under the master cylinder.
Originally Posted by FSM
Brake Master Cylinder Reservoir with Brake Master Cylinder Sensor
The fluid level indicator is an integral part of the brake master cylinder reservoir (2K478). It is serviced as a part of the brake master cylinder reservoir. It consists of a float and magnet assembly and a reed switch.
«1997 Aerostar/Ranger Table of Contents»
«Group 06: BRAKE»
«Section 06-09A: Brake System, Rear, Anti-Lock»
«DESCRIPTION AND OPERATION»
System Diode
The system diode together with an associated resistor prevents a false Code 12 from being set in the anti-lock electronic control module (2C018) when the parking brake is applied.
«Group 06: BRAKE»
System Diode
Electrically:
Looks like there's a variety of things that can cause a RABS code 12.
Code 12 is generated when the anti-lock electronic control module detects that the brake fluid level in the brake master cylinder reservoir (2K478) is low for one or more seconds. It can also be generated by a short in the stoplight circuit.
PINPOINT TEST CODE 12: LOSS OF HYDRAULIC BRAKE FLUID DURING AN ANTI-LOCK STOP
- Low brake master cylinder fill level
- Brake fluid leaks in vehicle brake system
- Worn or damaged master cylinder brake fluid level switch, or brake fluid level circuit shorted to ground
- Brake master cylinder reservoir float that sticks in the bottom of brake master cylinder reservoir or does not float
- Failed diode-resistor element in stoplight circuit
- Damaged ignition switch
- Ground short in Circuits 512 (T/LG) or 531 (DG/Y)
- Damaged anti-lock electronic control module
