Yep, got that out of the way and found that the leak was further up. Now I had to tear out the upper cabinets to get to the leak. So now its a plumbing headache. Plus I couldn't work on it yesterday because I had to get my daughters truck ready to go to the alignment shop.
I can't see it if it's a photobucket link, or something similar. You would have to do the pic as an attachment. The I/T ****'s here at work have photobucket, and all similar sites blocked.
Charlie, it started as a leak in the basement so I fixed that. Then after a test flush (with clean water lol) and found it was leaking further up. So I tear out the base cabinet and noticed it was higher up. So now I had to remove the upper cabinets to access the upper part of the pipe and it was rotting out there too. So needless to say, this has been an on going project.
