rear leaf springs
rear leaf springs
I have I believe the original springs and am looking to replace them. I want to know how much it will drop the back end with 3" drop leaf springs. I want to know if someone has newer rear springs on thiers and can give me a measurement to see how high stock is. Like a measurement from the rear fender to the floor. My truck could drop about 1" or 1 1/2" and still look ok. But if I have only lost 1/2" from original height I my have to figure something else out . Thanks
Are you looking to replace your rear springs because you have broken leaves or because you want to lower the rear? If the reason is the latter, you can first reverse the eyes on the main leaf and then remove up to 3 or 4 leaves depending on how you want to use the truck. Reversing the eyes is a simple matter of reshaping/reversing the the camber in the main leaf. That is most easily done on a press.
It sounds like lots of miles/rough roads with resulting wear. If there is any significant depth to the wear, I would opt for new or a better set of used springs.
It is hard to tell how much of a drop you will get, because we do not know how much your stock springs have sagged with age. Do a search for rear drops and you will find plenty of options out there. For a budget, with mild fabrication skills the axle over springs is the cheapest, but I would not recommend if you plan on pulling any weight.
stRanger706
1983 - 2012 Ranger & B-Series
11-23-2003 07:45 PM
