09 f-150 4.6 mileage drop
Hey all. Need opinions. My 09 f-150 with the 4.6 3v has had a considerable drop in fuel economy. Was getting 22 highway and 16 in town and about 13 towing on average 4k pounds. After I hit 50k it started to drop and now at 70k I'm getting around 7-8 towing, 12 in town empty and 16 highway... Any others seen anything like this?
Yeh I've thought Bout the fuel, but was told by someone at ford it's not a good idea to change until 100k... Made no sense to me...
Air intake filter? Never heard it called that unless this is different from the air filter...that's been replaced twice... And looks fine. Always used the same fuel. Always been 87 from either shell or Valero.
Dealers around here are crooks. Wanted to get some opinions here first since I've had good help in the past.
As far as fuel filters are concerned, if it were clogged it would run worse, or not at all, but all that time consumption would NOT go up, as the engine would be starving for fuel, rather than getting too much. The only filter that would increase consumption by clogging would be the air filter, and that has been dismissed as the culprit here.
The mystery continues.......
Another consideration may be the spark plugs. Although the spark plugs and other tune-up components are generally good for around 100,000 miles, with 70k miles on a truck you could have a single or more than one plug that may not be performing as it should. This would definitely affect the fuel economy.<O</O
But only by DECREASING it. The problem here is a sharp INCREASE in consumption. A restriction in fuel flow does not increase consumption. I've had loaded fuel filters before, so loaded the engine would hardly run, but fuel consumption did NOT increase.
A failed or failing oxygen sensor can cause poor fuel eco and loss of power. A scan for codes often can reveal if this is the case. There are often more than one O2 sensor in most vehicles/trucks. I'd suggest a scan for codes regardless as that could possibly tell you about the O2 sensors, MAP sensor and other issues that may be causing this.
While I agree that failure of any sensor would put the engine in "limp home" mode, I wonder if it would cause as great a drop in mileage as is reported here. I didn't think so, but I really don't know for sure. Maybe multiple-sensor failure, but would it even run then? And it's STILL a mystery....
