1988 F150 4x4 Project truck
I just acquired a 1988 F150 2 door supercab 4x4 long bed truck.
It has the 5.8 with auto trans.
Wanting to lift this truck but I am unsure how much lift I will need to stuff some 33's under it.
I'm looking for a look like this truck.
1988 Ford F150 4x4 - 1988 F150 xlt lariat 4x4
Does this truck have a 4 or 6 inch lift?
33 will just fit with 0 lift
33 looks good with 3-4 inch lift
35 barely fit with 4 inch lift
35 look good with 6 inch lift
The truck in the link is set at 4 inches, there is a photo of the axle pivot
Bracket with two holes for 4 or 6 inch lift.
The axle pivot is bolted to the holes closest to the frame.
Assuming all photos were taken at the same day, the truck looks like 4 inches.
I did not look at all the photos, some angles make the truck look
Taller that 4 inches of suspension lift.
Thanks for the speedy reply khadma !
I'm going to remove the bed and build my own flat bed. (For hauling 2 full size 4x4 ATV's)
Do most of the kits level out the trucks?
I also want to install air bags in the rear for when I have the quads on it. (Have a set on my 98 Mazda B4000 ex cab 4x4 and love them)
Thanks for the welcome! (I have been lurking here for a few years now)
khadma I found the bed build you referred too.
Lots of good ideas there.
I like the mounts. 1999 Dodge Ram 2500 Cummins Turbo Diesel Polyurethane Pucks Photo 8
Here is the link to the bed for future bed builders.
1999 Dodge Ram 2500 Cummins Turbo Diesel - Chase Bed - Four Wheeler Magazine
Skyjacker offers 6 different 4 inch lifts.
Can someone shed some light on whats going to be best for my primarily road driven project? I dont want to cheap out, but I also have no need to a full on off road kit either.
#184PKS-N is the one I think fits my needs the best.
Compare yours to this chart
I'm wanting to ditch the dual tank set up.
Will a Poly tank for the same year Bronco fit?
Price isnt bad.
33 Gallon Poly Plastic Gas Tank for Ford
Price isnt bad.
fordman16b
07-21-2005 01:12 PM
75hiboy
02-15-2005 11:34 PM
