Twin Turbo blow through 300
Keep in mind that these are power numbers at the wheels and your drivetrain may affect it..
From research I've done and other people's dyno numbers, @ below 10psi, a conservative range is from around 245hp and 400ft-lbs of torque to 250hp and 450ft-lbs of torque.
At boost pressures at above 10psi, the highest dyno run I've seen was 260hp and 573ft-lbs of torque @ 18psi, which was on a chipped piston also.
I've read that most boosted 300s start running into detonation around 11-12psi.
If you decide to put a turbo on your 300, the MINIMUM if you want to have your engine around for a while is forged pistons and high temp exhaust valves. If it's high mileage it needs an overhaul.
I first considered putting a blow-through 300 turbo in, but I didn't want to do the modifications to the carburetor and I thought I would have issues tuning it. In theory, you're supposed to retune your carburetor when it gets cold/hot because your mixture changes with the weather. When a turbo is put on top of that and detonation is a key failure to a turbo engine(without forged pistons), can you trust yourself to keep on top of the tuning to make sure it's perfect? I'm assuming it would be a daily driver.
Currently I'm doing my research to find the perfect daily driver turbo with a max rpm of 4000, maximum psi around 12. I'm going to make a custom turbo from turbonetics and so far I'm thinking these numbers may be close:
T3/T04E hybrid
57trim compressor
Ceramic bearings
Water cooled
F1-57 turbine wheel
.65 A/R
Anyone have thoughts?
T3/T04E hybrid
57trim compressor
Ceramic bearings
Water cooled
F1-57 turbine wheel
.65 A/R
After some searching, I did find a place with hydraulic roller cam blanks, but they said the price would rack up to $835, not to mention not having a ready supply of roller lifters handy. Seriously considering it, nobody I'm aware of has ever put a roller cam in a six.
Did some more searching on the lifters, it seems the lifter bore is the same as a 460, so a person could make custom tie bars and then use 460 hydraulic roller lifters in it.
I'm sure you've heard about others that make crossflow heads by chopping up 351? heads and welding them together. Why not take that a step further and "chop" up a v8 head on paper and piece it back together and have the CNC machine build it? Not much R&D for finding how to make valves and ports bigger then. I've heard of big numbers from people doing it that way.
Over on FSP there's a thread on an aluminum head that's been in the works for 4-5 years now - they finally got castings back from the foundry and are working on prototypes. It's a U-turn head, though, IIRC.
I was reading on my previous posts and realize I was all over the board on what I wanted to do with this project. I apologize. For clarity's sake, I decided against the roller cam, going with a custom flat tappet 212/212 grind from comp cams. No forged pistons, getting 8.5:1 compression hypereutectic pistons. I still need to call a turbo place about going with a 5.9L cummins turbo or ordering one from turbonetics.
On the question about forged pistons, anywhere that custom makes them. As long as you have the specs, they'll make whatever you want . . . for a price.
Update: Getting the block bored next week, then going to order the kit in. Stock gaskets, except the head gasket. Probably going to go with an MLS or copper head gasket so I can run 15psi of boost if needed, along with ARP head studs. High volume oil pump, and stainless steel exhaust valves.
The engine design is sturdy so i'm not too concerned with much else.
A tidbit of useless information also...on my efi 4.9L engine, the ford 2.3L and 2.5L HSC engines use the same pedestal mount rockers as the 4.9L. Of course, nobody ever made any performance parts for those inline 4's, but some searching on forums for performance stuff for those engines revealed a bit of info. Some people use Ford 460 pedestal mount roller rockers on them and use different length pushrods to make it work. By the associative property, wouldn't that reason to say the same would work on the six? (ponder)
On the megasquirt issue, holy cow is it complicated! If you plan on doing anything megasquirt, it's awesome at how much control is available, but be prepared to do a lot of reading.
On my '87 4.9L, it's a TFI system, so this is the setup I'm planning on:
-Megasquirt II
-TFI Ford adapter kit
-Electronic boost control kit
Megasquirt is cool because it allows a person to tune on the fly, using a computer.
I'll see if I can attach a couple photos of painted parts...
[IMG][/IMG]
[IMG][/IMG]
-Megasquirt II
[IMG][/IMG]
[IMG][/IMG]
I've been thinking about doing this to my 6 as well. But it will be awhile. I don't think I will build an engine with forged components but rather just a stock rebuild + fuel mods and tuning. I'd really like to see the manifold you modify, my fabrication skills are quite awful since I have no real welding experience. If there was a bolt on manifold I would have turbo'd my truck by now to be honest. I can do everything else.
I think a HX35 is perfect for this engine. Should spool fairly quick and pull all the way through the RPM range. Have you thought about injector size and a fuel pressure regulator? Most boosted setups I've worked with always required a 1:1 rising fuel pressure regulator, for 1 psi of boost 1 psi of fuel pressure will be increased as well. As far I know, the factory fpr doesn't work that way. Meth injection would be great paired with 93 octane. As long as you have no knock or detonation, even non-forged pistons will live a long life. The life of your engine will depend a lot on your tune. Mitsubishi used cast pistons (either 7.8:1 in the 90-94s or 8.5:1 in the 95-99s) and ran 10-12psi through 90-99 Eclipses/Talons, it was rare to have internal engine failure on those cars unless the owner neglected replacing the timing belts. If you can find 9.0:1 pistons they should work fine as long as your not pushing a ton of boost (say 15+psi) and you're not running a ridiculous amount of ignition timing.
I haven't been very decisive about injector sizes. I planned on using the stock 60psi regulator and tuning to make up for it being the type of regulator it is.
My plans for the exhaust were to join the two stock manifolds together and try to keep the two exhaust paths separated all the way to the turbo to help prevent reversion.
I talked to my machinist and we are ordering pistons with a target compression ratio of 8.5:1.
Don't forget with a turbo engine that exhaust gasses are higher. I would never do a stock rebuild and add a turbo. Custom grind a cam to get the most out of your turbo. Install stainless steel exhaust valves so they don't get soft and warp. Put in a better head gasket and use head studs instead of bolts.
I'll post pics when I get the exhaust piping done.
Thanks for the input!
I just bought an hx35 for my turbo 300 build. I'm deciding between megasquirt and the holley hp efi kit for fuel managment. From my research a hx35 is a good match. There is a member over on fordsix using one with good results, and the 5.0 mustang guys say it spools quick but restricts at high rpm. Sounds perfect for a 300 spinning 3500 max rpm. They are also extremely durable and have much aftermarket support. I have not yet tryed it, but I think it's going to work well
Here is a hypereutectic dished stock replacement piston I plan to use in my next build.
I have run roller cams in several 300s and 240s I have built. Some used 460 lifters. They are a drop in if you are using the Crane style with dog bones that separate. It gets a little more complicated if you use the type where the tie bars are held in with Allen screws, byt the C - C spacing is the same
I talked to a comp cams and isky and they could do one but it would cost too much. From comp cams, $835.15 for a custom grind.
I did a lot of research on the 460 roller lifters. I heard that there is some grinding required on the block on #6? Otherwise the lifter won't go in. Isn't the impression for the pushrod offset and not in the exact center for the 460 rollers?
Any roller lifter will rquire grinding of the #1 and #6 bosses for tie bar clearance. If the kind of lifter you are using has the tie bar on the outside they will work with no further work. If the kind of lifter you are using has the tie bar screwed on the inside they will need further work to fit.
#29
Hey FTF, do you think the roller cam in a ford 300 is really worth the input cost if, say, a person is driving it daily? (less than 3800rpm) Or would you only recommend it on race applications since rollers only really shine in high rpms?
I spent many sleepless nights with an annoyed fiance debating this issue over and over again in my head.
