Upgraded OEM brake master cylinder with power
If you do this before I do, let us know how it works out. If I beat you I'll review it so we all know. I'm also going to inquire about their brake pressure multiplier.
I hope to find one that Autozone or NAPA carries in stock.
Curious, is there any real difference between drum/dru/ and disc/drum MC's? Seems like the combo valve takes care of the different pressure needs? I have an '84 crown vic MC that just needs a clean and kit job
Sort of makes me wish I hadn't just bought an original style mc last winter..... On the other hand, I have lost brakes twice in single mc trucks, and my son did once driving my '69 landcruiser. Somehow, nobody was injured in all this. Wish I could say the same for the trucks. Is there a specific year and model truck I ask for at napa for that cylinder?
I thought that was the job of the proportioning valve. I know the M/C I have from an '84 crown vic has = reservoirs and it had disc/drum
Any master cylinder is normally going to give you plenty of warning before catastrophic failure,if you are at all awake/aware. So will your wheel cylinders, for that matter. Regular inspections,and just being an aware operator usually is enough. The most vulnerable part(s) on our old trucks' brake systems, especially a stock system, are the hoses.You usually cannot tell by a visual inspection that failure is imminent,and that will be a big problem for single chamber systems.
How many of you routinely change the rubber brake hoses when you purchase an old vehicle? Half the guys on the forum snivel about having to spend a dime, so I'm saying few here are willing to spend the hundred or so bucks for a set of quality hoses that might save your life. I nearly lost my wife and kids, when the front hoses blew out on our 63 Falcon. She stomped on the brake pedal at the bottom of the mountain, and ran through the red light, just squeezing through the stopped traffic and a line of parallel parked cars,taking mirrors off of both.She was not broadsided, though running the light, coasted to a stop, eventually, and they were scared manureless,shall I say.She was pissed at me, and I did a full brake job on the shoulder of the road.That car was sold.
Nevertheless, I choose to retain the stock set-up, changing all the hoses every 5 years, regardless of how they look. I will replace that master cylinder about every 7 years or whenever I'm feeling like my luck can't hold. These are cheap things to do,in my estimation, for peace of mind.
If you own an old truck,don't be a wedge-azz.If you think you can't afford to pull regular maintenance, or it's too expensive, get rid of it.I drive my old vehicles daily,they aren't a hobby for me,rather they are my only transport, so keeping them up is paramount. The wife drives new(ish) vehicles, I don' like or understand them.
Some day, I'll own another 63 Falcon Wagon.
#28
#30
