New Member- My '51 Project So Far 2" Chop (Pics)
_______________________________
48 Ford F1 - Dark Side
46 Ford Tudor - Street Rod
"BEWARE of high performance trucks with low performance drivers"
I am sure if you knew the hood was the wrong year you know the bed is the wrong year... Just hoping to save you some cash on parts if not... Looks like a 48-early50 bed.
Make sure you document the drop if you keep straight axle... I am looking to do the same thing eventually. If you know of a good source of info on how to do it I would like to see... The info I have seen is for drop axles and spindles.
The rear is always the easy part... The more I think about it the more of a deal you got... makes me feel taken on mine when I had thought I had got a good deal.
This might not be an issue for you but when I had to replace my 48 hood due to major damage with a 51 hood I found the 51 metal was 18 guage and my original hood was 16 guage.
Yeah, you can never have enough garage space, but I like my setup. We are looking to move soon, but part of the trouble I'm having is finding the kind of place we want AND the right garage space.
Dropped axle Axles Axel
Takes about 6 weeks, and he does a GREAT job. Cost me $400 for the axle stretch and new kingpins (installed) plus about $80 shipping round trip.
Here's a pic of the front axle installed with the front clip sitting on the frame. The motor and transmission are installed, and the wheels are 15 inch with P215/70R15 tires. I also have reversed-eye main leaf springs in the front, available from www.classic-haulers.com.
There are no dropped spindles for the beam axle. You can use the same techniques as the 53-56, removing every other leaf, using lowering springs, use reversed eye springs, use extended shackles, use dropped axle. The link already provided is dropped axles done right. You can drop the front until the frame will scrape going over speed bumps and the bumper will scoop up road kill less than a week old!
You can't flip the front axle to the top of the springs, but you can on the rear, but you will need to C notch the frame.
49willard
24
06-03-2015 07:42 PM
John & Old Ford
12-18-2013 12:22 PM
r_reed
09-24-2011 07:01 PM
