1960 f100 wirring
Old 09-27-2012, 01:14 AM
56 ford custom's Avatar
56 ford custom
56 ford custom is offline
1960 f100 wirring
I am contemplating on completely rewirring my f100 but I would really like to keep the factory style wirring and not some generic aftermarket kit. I noticed where the harness plugs together at the firewall on the drivers side near the master cylinder its a rectangular plug. I am running all actual working gauges(not dummy or idiot lights) from a bigger f-series truck of the same year with air pressure gauge and a tach. I'm not sure if I want to go with an alternator or keep the generator? Who makes new harnesses for this year?
Old 09-27-2012, 04:09 PM
56 ford custom
f100
Anyone know about the 60?
Old 09-27-2012, 06:52 PM
spurredon's Avatar
spurredon
spurredon is offline
I recall this being discussed but not the names of the vendor. I do remember that you will have to bring you wallet though! If you are not using original guages and perhaps not generator, why would you want an original harness?
Old 09-27-2012, 07:38 PM
spurredon's Avatar
spurredon
Did a little looking around for you and came up with this seller on ebay that list a harness for a '59 and a '61 for around $400. From what I recall, that is a good price.! I would think if you contacted them they could do you a '60! FORD PICKUP 1932-UP items in truck harness store on eBay!
Old 09-27-2012, 07:48 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
After an exhausting in depth search of this forum using the terms "1960 wiring harness".
OK it took two minutes. But it was easy, almost anyone could do it!
YnZs Yesterdays Parts | Classic, Antique and Custom Auto Wiring Harness | (909)798-1498
Good luck in your quest
Old 09-28-2012, 11:10 AM
56 ford custom
f100 wirring
Well they would need my old harness also if I am not running idiot lights and possibly not a generator...then that harness would be useless?
Old 09-28-2012, 01:36 PM
56 ford custom
f100 wirring
Also if I were to go with a universal aftermarket harness what would I have to do with the rectangular hols from the old harness that plugs into the firewall?
Old 09-28-2012, 02:50 PM
theodore/teddy
Refyred
Yea thats the problem with these old trucks. When you move away from stock you have decisions to make. What to do what to do?
Good luck in your quest.
Old 09-28-2012, 03:59 PM
56 ford custom
f100 wirring
Anyone else go through this with their. 60
Old 09-28-2012, 06:21 PM
spurredon's Avatar
spurredon
Any ideas what a universal harness would look like? Would it be home run wires from the fuse box to the devices or would there be some connector plugs in between. If it comes thru the firewall in a round bundle, just cut out two rectangular pieces of thick rubber a little larger than the orininal harness port and route the new harness thru the rubber blanks with a hole cut to except them. The rubber can be either cut to friction fit into the hole or if made larger enough, glued or screwed to the firewall. I have never done this as I used three original harnesses to restore my existing but with a little creativity you can come up with something you like. Sometimes when you hear ideas that sound dumb it makes you think of what you really want to do by thinking about what is wrong with someone elses idea!
Old 10-02-2012, 01:18 AM
idaho211's Avatar
idaho211
idaho211 is offline
Congrats on working on a 60 ford. I have dealt with Alloy metal products out of New York for stock complete wiring harnesses. They were made from NOS harnesses and or ford blueprints. New fuse box is included. He has made up some additional harnesses when I ordered a complete one last year. Complete harnesses including all wiring, dash, engine, body, signals, lights, heater, were around $800. I did see NPD offered 60 year for a while but is now out of stock again. Adding up all indivicual pieces was over $800. I have put in two new complete harnesses in both my 60 trucks and they fit perfectly. Let us know what you come up with. Good luck!!
Old 10-06-2012, 04:38 PM
transam525's Avatar
transam525
transam525 is offline
I've used YnZ to reproduce my 1960 harnesses with nothing but outstanding results. Reproduction of the harness will take a few weeks, as YnZ assembles the harness then sends it to another local shop to mold on the correct plug ends. In return, you will receive a harness of exact appearance to that of your original. For your situation, simply you can work with YnZ to add or delete any wires to your reproduction harness for your add-on accessories. Unfortunately, any changes you make to the harnesses feeding into the firewall may warrant alteration of your dash harness.
Old 10-06-2012, 06:56 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
This relates to my project '59. I got it without any wiring at all. I saw something on original wiring from Sac Vintage Ford (I think?) I'm def going with a later ford alternator so I'm guessing modding will be needed. OP, nice find getting full gauges from a bigger truck! I'm jealous.
Old 10-12-2012, 02:37 PM
56 ford custom
wiring
I'm just worried about the two rubber plugs
Old 10-12-2012, 05:06 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
At $800 I think I'll go with an aftermarket harness and figure out what to do about the firewall connection at that time. I'll prolly weld the existing hole shut and make a new one. Aftermarket harnesses are around $300
Quick Reply: 1960 f100 wirring
