Use of courtesy time out
#261
#263
I've been all under the truck and a friend's truck that does have them and mine are simply not there. I'm going to go by the dealership next week to see if they could be added and if so what cost. Most than likely I will tap into the wire under the door sill and run it to a relay to power the lights. Just may take me a while as I injured my back again yesterday at work. Not as bad this time, just gonna keep it slow for a bit.
#264
Well I hope you get better. This is a crappy time of year to have back problems. I checked for mine while I was running the wires for the bed lights and I have them. I ordered 2 sets of lights because I couldn't see whether or not each set had wires on both ends. I'm glad I did because they only have wires on one end. I may try to loop each set back for twice the light somehow. Each set is 5m so I have twice as much as need. Once I get this done I think I am mounting some LEDs under the rear bumper for extra reverse lighting. I haven't decided how I'm wiring them yet. I'm thinking from the upfitters because I already have the wire running from the engine to the bed to connect to. Then again I may just connect that wire to the battery and switch them from the bed of the truck so they are hot all the time. Or maybe I will add two sets and do one set each way.
#265
#266
#269
Description
The 2-pin connectors we offer make it possible to connect single color LED flex strips without having to solder. The design of the these gapless connectors includes channels that allow 10mm wide LED strips to slide into the connector and underneath the 2-pin connections (shown in the image to the right). The clamp covering the connection needs to be opened and after the strip has been inserted the clamp can be closed firmly to hold the wires in place. A full explanation of these connector clips and how to properly use them is available on this post: LED Strip Connectors - 2 Pin & 4 Pin: Quick & Easy Alternative to Soldering.
#270
I tired some of those when I did my RGB on the 5th wheel. I couldn't get them to work too well. I just used one reel under each side of the truck and it worked fine. I only paid $10.85 for both reels including shipping so it didn't hurt too bad to cut them in half. The connectors were less than $6. So for about $17 bucks plus a little black tape and a few connectors I'm real happy. I ordered the reverse lights today so that's next on the list.
