Installing 300 l6 into 1959 f100
Old 09-22-2012, 12:12 AM
fender72's Avatar
fender72
fender72 is offline
I have a 1959 ford f100 that someone installed a 239 y block in. I want to pull that out and install a 300 inline six,and was wondering if the t98a transmission would bolt up to a 300. Also will I need to change the motor mounts and trans mounts? Are there adapters to adapted the bell housing from the y block to the 300 l6? Any help on this would be great!
Old 09-22-2012, 12:44 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Panties NOT in a Twist
Fender,if you use the search function for this forum,check out what member "Col.Flashman" has done with his 1958 w/ built 312 I6.It is really impressive.
Do not believe the T98 will bolt up without an adapter,I could be wrong.We also have an Inline 6 section in FTE's Forums.Good luck.
Old 09-22-2012, 12:47 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
It shouldn't be too hard to just switch to a t18/19 or NP 435. You will have to deal with the clutch actualtion issue. I think there were some early 90s pickups with 4 speed that used an external hydraulic clutch and you could find one of those bellhousings. Otherwise you will be looking at dealing with the hydraulic/ manual clutch conversion. It might also be a good time to just get a ZF or Mazda 5 speed, they are hydraulic too but the slave is inside.
The old T98 are tough but unless you routinely need the compound 1st gear, they are just a big clunky shifting 3 speed.
Old 09-22-2012, 12:48 PM
HOTWRENCH's Avatar
HOTWRENCH
HOTWRENCH is offline
300 /6 install
You can use a bell from a later F series with the 300 six . I don't know what year the smaller trucks went to the side mounts on the engine but the larger truck bells with side mounts will work for you, the front mount will fit also.
Many of the F 500 up trucks used the T 98 trans with the same bolt pattern as yours. Let me know if you need more info.
Have A Great Day ------ Hotwrench
Glxy66
07-16-2019 08:02 PM
mark72newk
06-27-2006 07:51 PM
dablack
12-08-2004 03:05 PM
Herman
09-07-2004 06:24 AM
58Model
12-26-2001 03:28 AM
Quick Reply: Installing 300 l6 into 1959 f100
