Hemi swap!?
#31
#32
But I do agree with you that the Dodges before and after the '70s PWs were pretty ugly. I had a '86 D250 for awhile good truck had the same tranny my F150 has but hideous to look at.
#33
#34
When you said hemi first thing I imagined the 429 boss engine haha
Anyways, I was wondering where you got that air cleaner on your 351??
I've been looking everywhere for that!!
#35
Top Ten Reasons
Top Ten Reasons this thread deserves reps:
10. Decent grammer and proper sentences in posts.
9. Pictures posted.
8. Fast progress on project.
7. Decisive OP, note "2 seconds" to decide on Hemi when he discovered the deal.
6. Killer deal on the donor
5. He's had the truck since he was 12.
4. Former Navy man going to school still has time for this project.
3. Did the 351w/C6 swap before many here had their driver's license.
2. First cross-brand post that has generated zero hate.
1. First "Hemi swap" thread where OP actually knows what he is doing and the reader can be confident the truck will be running again soon.
There may be other reasons.
9. Pictures posted.
#36
Yeah the 426 Hemi is legendary. There are builders out there that completely re-sleeve and stroke these 5.7 Hemi blocks to make them 426 ci. But I don't have that kind of money. I got the air cleaner and valve covers as a birthday present, I think when I 13 or 14. So I've had those for a while now. I don't know if Ford racing still makes them or not.
#37
9. Pictures posted.
9. Pictures posted.
#38
http://www.allpar.com/images/engines...treet-hemi.jpg
He is talking about the Ford Boss 429:
http://www.wrljet.com/fordv8/images/429boss-lf.jpg
which has modified hemispherical combustion chambers.....
#39
joel79ford is not talking about:
#42
Alright well I finally have an update. I haven't done too much but last night I pulled the engine and transmission back out. And today I started to weld up some of the many unnecessary holes in the fire wall. Tomorrow I will grind those welds down. Also when I first started working on this truck many years ago I tool the HVAC stuff out and just put in a steel plate. I went ahead and just put some light gauge steel in place and I started welding that up too. I would like to have a relatively smooth firewall and engine compartment. It is still going to be a daily driver so I'm not going over board, but I want it to look good because I'll probably be poppin' the hood quite often.
#43
Also something else, I took out the steering column and compared it to the Ram steering column. It looks like I shouldn't have too much of a problem getting it to work for me. But one thing I did have to do is modify the spot in the fire wall that it goes through. The hole is originally shaped like a tear drop or something.
This shape is what I need for the Ram column, however i just need the hole to be flipped 180 degrees. So I went ahead and cut it out and tacked it in for now.
Once I get to where I am starting to hook all that stuff together I'll go ahead and weld that all up. This particular piece is double plated so when the time comes I'll just TIG it on the inside as well.
#44
And lastly I was just messing around before I came inside. I wanted to see if the Ram gauges would even fit in my dash. I've seen most other guys go with aftermarket gauges when they do swaps like this. But I'm trying to reuse the factory harness and everything so I think using the factory gauge cluster would greatly facilitate the swap. And it just so happens to fit. I'll just have to make a bezel to work with it. I've worked with fiberglass before but recently I've been seeing some guys do their own work with carbon fiber mat. And after seeing that, I think that's what I will shoot for. But here is a picture with the Ram gauge cluster sitting in.
It'll be a tight fit but nothing unrealistic. I'll get everything to fit nice and snug. As if it were meant to be there in the first place.
