Please welcome MuddyHill
#61
#65
Received 5,160 Likes
on
#68
Barry early in the day is good for me. I get off work at midnight tomorrow. say 1000. I will pm you my number. as for an oil filter the motor craft filters are good. I use them on my truck in my signature. as for oil 15w40 and say Mobil 1 or motorcraft oil. those are my preferences. you usually get the oil and filters at Walmart and save a few bucks over what the dealer and the parts store would charge.
#69
#71
#72
on
#73
Use Shell Rotella 15 w 40 in that, it has zdp in it for your flat tappet cam. I would go to advanced because they will look up the filter for you, and make sure you get the proper wrench to remove the filter, as I said before, the filter is larger in diameter that a normal filter.
I use luberfiner filters on all my diesels, but you can go with Baldwin, or motor craft. Btw, you need to pick up 4 gals, as you will use 14.5 qts
#74
on
#75
