Finally! New X/C code springs in!
#61
on
I know this is an older thread but I'm planning on doing this real soon for my new to me 00 EX V10 . I was looking on SDTruckSprings site and they are showing the V codes & X codes as the same number. I quess my question is this how stiff or rough will it ride with the V10? It is a big rig & I don't mind if it is a little stiff or rougher than now. It actually squishy now at times since it has load range D tires on it. Looking at LT295/75r16's to put on all 4 corners. My plan is to do a 12V Cummins swap in the next year or so. This is my first Excursion & really like it. Thanks for advice, info & opinions.
Randy
Randy
#62
I would bet that the x codes would be a little much for a v10. They are fine on the heavier diesels. However there are several guys on here with them on their v10s. It all depends on how you want the truck to ride and if you are going to put a heavy bumper and/or winch on the front. They are not too stiff for the diesel in my opinion but I don't speak from any experience with a v10.
#63
Agree, the x codes gave me about 3"+ in lift and under my 7.3 the ride is awesome, not stiff at all but just the right amount of stability. V codes may be better for a V-10 but you could always look up engine weight compared to a diesel and decide from there. If you are doing the Cummins swap, my opinion would be X codes and not looking back, those Cummins blocks are very heavy
#64
on
#65
#66
Just FYI, the SD Truck Springs you have are more like V codes.
V codes are 5200/pair, 2600 per.
W codes are 5600/pair, 2800 per.
X codes are 6000/pair, 3000 per.
So the springs you have, item #43-818 rated at 2630 per, are more closely spec'd as a V code.
Ya might wanna change your sig.
If you look, 43-818 is being listed as the same replacement spring for the V code, W code, and X code on the SD spring site.
Stewart
#67
According to the SD truck spring website, part #43-1263 is rated with a 3000lb spring capacity (6,000 for two)
Rear spring codes:
A = F-250 & Excursion (6,084 pounds @ground)
B = F-350 SRW (6,830 pounds @ground)
C = F-350 DRW (8,250 pounds @ground)
Again, just FYI so you know what you have, and for anybody else who reads the thread so they know what they are ordering when they order from a place other than Ford, claiming to have V codes or X codes, etc.
Stewart
#69
Due to another thread in the 7.3L forum, I remembered this thread and got curious because I remembered you stated you have X codes on your rig now.
Stewart
Stewart
#70
Stewart
#71
I looked at the springs from SD and was going to buy but decided to go with Ford parts from Tousley, got a great price, like others have said some of SD numbers didnt quite match up when I was looking
I have Ford X codes from a Ford dealer, and my truck does not ride rough at all
#72
on
#73
#74
#75
