Rear Axle ID
Old 09-07-2012, 01:11 AM
Samsn4's Avatar
Samsn4
Samsn4 is offline
Rear Axle ID
So far I believe the body is a 56 and frame down is a 53. the glove box plate says 56, but the placement of the fuel cell says 53. Anyway i believe i have a Rockwell, not sure. I did the wheel spin and came up with 24.25 spins at the drive shaft for ten rotations at the wheel, so that would be 2:43, correct ? back plate to back plate is 53" I think. there is also a casted number on it "3162"
I'll get pic up in a couple hrs, work pc will not let me
Old 09-07-2012, 01:22 AM
Samsn4's Avatar
Samsn4
Samsn4 is offline
Cheating the system
https://picasaweb.google.com/1032175...eat=directlink
You will also see the pile of crap that followed after pounding one of the leaf spring pins out.
Old 09-07-2012, 04:17 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
That's a Timken A150 from an early F-250, probably a '53 like you said. The hub caps give a second confirmation that the chassis is an F-250. Gear ratio would be 4.86/1. Don't through the hub caps away, guys are looking for them. The 16" wheels too for that matter, depending on what your plans are for the truck. Stu
Old 09-07-2012, 04:48 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Timken A150: 1953/56 F250 / Available ratios: 4.86-1 & 5.83-1.
2J-1130-A .. Hubcap / 1948/52 F2/F3 / 1953/56 F250/350.
Old 09-07-2012, 10:14 AM
Samsn4's Avatar
Samsn4
Samsn4 is offline
Ok, yeah i plan on keeping the wheels, so that is a bit different to my first post, b/c the glove box plate has 4:86 stamped on it, Hm
Old 09-07-2012, 11:25 AM
truckdog62563
Why is that different than what Bill and I posted? Stu
Old 09-07-2012, 01:37 PM
Samsn4's Avatar
Samsn4
Samsn4 is offline
different from what "I" posted, my initial thought was that my truck has been pieced together, but now since the ID plate in the glove box matches the rear end that i have, i'm think now, this truck actually goes together.
Old 09-07-2012, 02:00 PM
truckdog62563
Oh, I see. Do you plan to keep it stock? Some guys swap this axle for a Dana 60 from a 1972 or earlier F-250 to get a more highway friendly gear. Stu
Old 09-07-2012, 05:23 PM
Samsn4's Avatar
Samsn4
Samsn4 is offline
for now I'm planing on swapping it out, got a lead on a dana 60, 2.23, disc, just need to find out the width. But would love to keep the stock and install a Gear Vendors.
is there an 8 Lug Dana 60 ? I would love to keep my stock wheels, I'm installing a front disc kit from The Street Rod Mfg, the only one I've found that's 8 lug.
Old 09-07-2012, 05:39 PM
55F250's Avatar
55F250
55F250 is offline
Which is it?
LMC truck catalog calls it a Rockwell A150, so which is it?
Old 09-07-2012, 05:51 PM
NumberDummy
1948/56 FORD TRUCK PARTS CATALOG / TEXT, PAGES 145/146 = TIMKEN A150
Sometime after 1956 Rockwell acquired Timken, became Rockwell-Timken. But, there is no FORD TRUCK PARTS CATALOG ref for a Rockwell A150 or Rockwell-Timken A150.
LMC has no friggen clue, their catalogs are rife with errors and omissions.
Is their an 8 lug Dana 60?
How many would'ja like?
8 lug 6.50" bolt circle pattern Dana 60: 1954/86 F250 / 1969/74 E300 / 1975/86 E250 / NOTE: Dana 70 looks very similar to a Dana 60, has the same 8 lug 6.50" pattern (after 1966). Only installed in E/F350's.
There's also a Dana 61-1, looks similar to the others.
What does 2.23 refer to inre to a Dana 60, the axle ratio? No such thing was ever offered by FoMoCo. Common ratios: 3.54, 3.73, 4.10, 4.56, 4.88 / 3.00 & 3.23 introduced in 1980.
3.00/3.23/3.54: Everyone wants one, few find them.
8 lug 6.50" bolt circle wheels: 1953/98 F250 / 1967/98 F350 / 1969/74 E300 / 1975 thru today E250/350 / F250/350's went to metric wheels in 1999. No Econoline has metric wheels.
Old 09-07-2012, 06:02 PM
55F250's Avatar
55F250
55F250 is offline
Kinda like DANA/SPICER?
Old 09-07-2012, 06:28 PM
truckdog62563
Let's see if I can muddy it better. Bill already posted the best reference, pages 145/6 of the chassis parts catalog, 1964 edition. The Jan/54 edition, however, is silent to the manufacturer. Further, the Hollander Interchange is silent to the manufacturer. And the Ford Service Forum 1953, Booklet #8, Servicing The F-250 Rear Axle , is silent to the manufacturer. My other source for the manufacturer, though, is the James K. Wagner book Ford Trucks Since 1905 where he says on page 252 that the F-250 got a "Timken-Detroit hyphoid rear axle". Stu
Old 09-07-2012, 06:37 PM
NumberDummy
1948/56 Ford Truck Parts Catalog: Chassis only for 1948/52 / Chassis & Body 1953/56.
1944/52 Ford Body Parts Catalog reprinted by faxonautolit.com (75 bucks and it's 1/2 the size of the original-y'all may need a magnifying glass) / Includes Ford Passenger Cars & Trucks.
Last Friday, I was in Riverside (CA), so I whizzed over to Faxon's store, warehouse is more like it. I've never seen so much literature in any one location, it's mind boggling.
Rows and rows of bins over 30' high. But, Ed didn't have what I was looking for, a Standard (hardware) Parts catalog that covers 1979 and earlier.
It was Spicer originally, then Spicer/Dana, now it's just Dana.
Old 09-07-2012, 06:41 PM
55F250's Avatar
55F250
55F250 is offline
Quick Reply: Rear Axle ID
