2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Rear Gear ratio?
Old 08-31-2012, 07:09 AM
Jay87LX's Avatar
Jay87LX
Jay87LX is offline
Rear Gear ratio?
Is there a way to tell via the VIN what is my rear gear ratio?
<!-- / message -->
Old 08-31-2012, 08:50 AM
MCDavis's Avatar
MCDavis
MCDavis is offline
The VIN itself...no. The VIN run through a model decoder...yes.
The easiest way is to look at the white driver's door tag, located on the door itself facing you when you open it. Lower portion of the door. There should be a 2 digit code under "Axle Code". Two numbers is an open diff, One letter and One number is a limited slip.
Once you locate that axle code, then this link should help:
Ford Door Sticker Decoder .: Articles
Old 08-31-2012, 02:55 PM
Jay87LX's Avatar
Jay87LX
Jay87LX is offline
Thanks- I have 3:55 LS
Old 09-01-2012, 10:04 AM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
What year Expy do you have ?
Assuming you have a 2007 and up Expedition (your in the 2007 and up forum)then you either have 3:31's or 3:73's.
And if this is true, you dont have LS either.
Matt
1982_f150
03-28-2021 04:58 PM
F.Phipps
1983 - 2012 Ranger & B-Series
01-22-2009 05:19 PM
tunaluvr
10-24-2008 12:08 AM
New To Ford
2004 - 2008 F150
03-14-2006 12:11 AM
Duderoy
02-03-2003 10:37 PM
Quick Reply: Rear Gear ratio?
