1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Wheel and Tire, Seat Belt Qs
Old 08-24-2012, 06:17 AM
98GP's Avatar
98GP
98GP is offline
Tire and Wheel Q:
I am looking to purchase a 2004 F250 XLT, FX4, V8 gas. It currently has the 16" wheels with the round hole pattern. I would like to switch them to the 20" five spoke wheels with stock 20" tires. See link, Ford 20' Wheels and Tires
Will this tire and wheel combo fit the wheel wells and not rub on the front when turning?
Seat Belt Q:
Same truck... The middle rear seat only has the lap belt. Can the lap belt be replaced with a 3 point seat belt? Aftermarket or newer factory? Has anybody tried this?
Thanks
Old 08-24-2012, 03:19 PM
schmidt64's Avatar
schmidt64
schmidt64 is offline
Those wheels will bolt on but the offset is wrong so they will look a little silly and rub on full lock as well
Old 08-24-2012, 03:36 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
you'd have to run 2" spacers to utilize those rims
not safe IMO for the potential weights a F-250/350 can see.
secondly, no on the seatbelt. there isn't any cab structure to support a shoulder belt
Old 08-24-2012, 04:13 PM
98GP's Avatar
98GP
98GP is offline
So the axle widths are different amongst F250 Super Duty trucks?
10-4 on the seat belts
Old 08-24-2012, 05:21 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
99-04 trucks are 4" narrower axle widths than a 05-13 trucks
Old 08-24-2012, 05:42 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
whoops, I forgot the newer trucks had the seatbelt support built into the seat itself.
the seats from a 08-13 bolt right into your 2004. Find a good deal on some and you can have that shoulder belt. Not to mention that most likely your current seats are a little worn after 8 yrs. 2 birds 1 stone
Old 08-24-2012, 08:04 PM
98GP's Avatar
98GP
98GP is offline
Good info, thank you.
pburress
01-08-2012 03:35 PM
bigcountry1009
16
12-14-2008 07:05 AM
xnorp
03-16-2006 02:43 PM
Quick Reply: Wheel and Tire, Seat Belt Qs
