1951 Ford F1 Front Cab Mount
I am hoping someone may be able to help me with the order of the rubber pads and metal washers/shims. Not sure if washers/shims or rubber pads should be against frame mount. I'm assuming the order will be the same on the next mount back as well. I've looked at the pics in the catalogs but find it hard to discern where the metal pieces go. Unfortunately I've had the truck apart since 1996 and I'm finally getting back on it as life permits!
The following users liked this post:
GoldCo
08-02-2017 07:17 PM
burnettd01
09-17-2015 12:43 PM
