This is prolly a 1 page thread at most
I did the exact opposite to reinstall my new box. No lumber necessary. Just my truck and 5th hitch. I set the new pinbox in the hitch, backed the box under the mounting wings, and used the landing gear to lower the RV over it. I got the front bolts in loosely and was able to raise the rear of the box the last few inches by hand and get the bolts in. Did the same on my last rig.
Evening guys. Just getting back into the station. We just had a fatality house fire. We were first in and could do nothing. Too hot to approach without gear. The victim was gone before we even got there. He had family members across the street and they watched it all. Been busy otherwise too. Gonna try to get cleaned up and rest a bit. Have a good night.
I had a roll-n-lock on my my '11 Ford and I really liked it. The last winter it froze up on me a could of times. My truck stays in a heated garage so it normally isn't a problem. A few weekends sledding cause some issues though. I think I might go MX-4 route. I know Dak had a BAK Industries something or other and he likes it.
Just ordered the MX4. I like that you can open or close the tailgate with the cover shut and locked. You can also shut the cover with the tailgate locked. You only have to open the tailgate to open the cover.
I've had roll and lock and pace edwards rolling covers - in fact I have one in my garage. The roads here twist the truck so much it pops open all the time, which is aggravating. Although from what I read, the Fiat's don't twist as much so it might not be a problem.
Finally, the new Extang folding covers will allow most of the last section to flip up. Now I can also say that out of ALL of the covers, the extang is the easiest to remove.Two wing nuts after the cover is folded. Which is nice, because sometimes you just want a completely open bed.
I'm going back to packng.
Monty have a safe 100 hour week. Geesh that's a lot!
Got a new 'fun' fact.
I parked in my new driveway - which has a pretty steep angle to it. Needed to add some fuel as I was running down and I filled up a bunch of jerry cans (Fred Meyer fuel discount was up to 35 gal of diesel for $1.61). Anyhow, I was at half tank and I could only put 2 gal in before it hit the fuel filler neck - apparently I was at a steep enough angle to prevent the vent from allowing more fuel in.
I recently needed to adjust the height of it, so I strapped it to my loader bucket before removing the bolts. Then I lifted it into place with the bucket and bolted it back down. That machine is a real back saver.
Received 4,043 Likes
on
My Montana came equipped with a Moryde pin. It seems to make for a smoother ride than my previous 5ver.
