how to remove dash cover to install switches? -- 99 F350 Lariat
Old 08-16-2012, 09:24 AM
eyyu's Avatar
eyyu
eyyu is offline
Bricks & PSD
I’m getting ready to add a few manual switches to my new 99 F350 truck. If you did something similar to the factory dash cover as shown in the picture below, please let me know how to either remove that little square thing so I can install the switches on it or, if it’s not separable from the rest of the cover, how to remove the entire cover without breaking any plastic parts? I’m mainly thinking about a TC lock-up, a Exhaust brake, maybe a GPR manual switch. I want to place those switches in the right spot and leave room (if any) for future expansion. What do you all think? Thx. Erwin
Old 08-16-2012, 09:37 AM
Christof13T's Avatar
Christof13T
Christof13T is offline
My switches are in the same spot your talking about..
Have a switch for the idm fooler switch, and 2 for the tc lockup and exhaust butterfly.
Mine are actually mounted to my 4x4 selector switch panel.
You can get switches to your liking... and cut holes with a dremmel or something...
I just have simple toggle switches so they mounted in drilled holes.
Xtof
Old 08-16-2012, 09:55 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
pull the bezel, snaps right off. I have an extra fuel gauge, in that same area.
Old 08-16-2012, 10:09 AM
eyyu's Avatar
eyyu
eyyu is offline
Bricks & PSD
How? I ran a needle along the grove and it feels like one piece withe the rest of the dash cover.
Old 08-16-2012, 10:11 AM
Deluxe06's Avatar
Deluxe06
Deluxe06 is offline
4000 rounds a min
Here's a little wright-up on how to remove you dash panel, if need be.
File Type: pdf
Old 08-16-2012, 10:32 AM
eyyu's Avatar
eyyu
eyyu is offline
Bricks & PSD
Richard, That's very usefull information. I'll keep the write-up in my collection. Anyone knows if the square thing alone is removable? Erwin
Old 08-16-2012, 10:56 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
No, it's molded into the bezel. You would have to cut it out with some sort of tool. I cut out mine and then fashioned a metal cover plate...mounted everything to the plate and then screwed the plate to the dash. This way I can access the wiring without having to remove the bezel again.
Old 08-16-2012, 11:32 AM
eyyu's Avatar
eyyu
eyyu is offline
Bricks & PSD
Greg, Thx for getting me the right answer.
Old 08-16-2012, 12:43 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
SpringerPop's Upfitter Switches
The switches.. Thanks to SpringerPop.
Old 08-16-2012, 01:06 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
Dont just pull it out... You have to remove the stereo first and remove two bolts in there...
Old 08-16-2012, 01:24 PM
eyyu's Avatar
eyyu
eyyu is offline
Bricks & PSD
CSIPSD, just where on earth did you find those buttons with indicator lite? How about the mounting plate? WOW. beside all the expertise in PSD technology, we have some serious artistic minds here!
Old 08-16-2012, 01:28 PM
eyyu's Avatar
eyyu
eyyu is offline
Bricks & PSD
looking more carefully at your picture, now I see two more switches (toggle kind) beside the 6 on the plate. What are those 8 switches for? very nice setup with the gauge under dash gauge pod and CB radio.
Old 08-16-2012, 02:02 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
As to the switch plate... It came from a boat shop in Astoria Oregon... Its worked fine over the years however there is no way to label the switch which is a pain.
The ones below are for my strobes and mirror heat. They were there before I installed that switch plate so I am stuck with them down there, or have holes.
Old 08-16-2012, 03:11 PM
VegasFordSD's Avatar
VegasFordSD
VegasFordSD is offline
which one drops the landing gear?
Old 08-16-2012, 03:33 PM
F250_'s Avatar
F250_
F250_ is offline
Here's a starting point for similar switch mount options. Marine Switch Panels - iboats
And this company might also have some things you might be interested in. http://www.paneltronics.com/ip.asp?e...s=OEM%20Panels
Quick Reply: how to remove dash cover to install switches? -- 99 F350 Lariat
