49 Ford F1
#346
#348
I don't know what your plans are for the bed floor, but the guys at hot rod magazine did this with their muscle truck. It might give you some ideas.
Muscle Truck Revamp on a 1974 Chevrolet C10! - Hot Rod Garage Ep. 5 - YouTube
#349
#350
#351
I'll have to take a look tomorrow, but im pretty sure its solid other than around the edges and one or two other spots.
#353
The steering linkage is now pretty much done. Next time i pull the motor i will finish welding the nut that is holding the support bearing to the frame. I only have the top half welded now.
One thing i found that kinda pissed me off is that the rack mount bushings are already dry rotted and need replaced. The truck hasn't even been on the road yet! I think i might try some urethane bushings instead of rubber. Anybody have any experience with those?
Next up will be brakes. I got all the brake hoses and hardware needed to route my lines, so i'm gonna get that done next. The one thing im still deciding on is where to mount the proportioning valve. It is adjustable so i wouldnt mind having it somewhere that is easily accessible, but i don't want to mount it so far away from the master cylinder that i need a bunch of extra lines.
#354
#355
Got most of the brake lines done today but ran out of line. I did the line to the right front caliper, the line to the rear brake hose and the line from the t on the rear to the left rear caliper. I also got my rear calipers painted. I'm very glad my dad got a hydraulic flaring tool. It is so much easier. Just waiting on the brake line to get here now.
#357
Brake lines are now done. Just waiting on a replacement front caliper as it had the wrong inlet size. Next I have to decide how i want to fill the master cylinder. Should I cut a hole in the floor for access or run a remote fill reservoir? I'm leaning towards remote reservoir but I kind of wanted to find a vintage looking reservoir but I can't find many and the ones I do find are way more than i want to pay. Should the reservoir be a specific brake/clutch reservoir or could I custom make something that looks vintage?
#358
#359
Not vintage, but the 92 Camaro with T56 tranny used a hydraulic clutch MC (uses brake fluid) with a remote rez that is small and translucent white plastic. Here's a pic of the entire assembly:
Rez is the whitish part in the lower right corner with the black tube leading to the Black nylon MC.
#360
