49 Ford F1
#331
There's not a enough advantage to having a thermal clutch, enough that I'd go electric. You can easily get a plain old fan in there. I bought an aftermarket 6-blade fan, 18" diameter, and the fan blades are pretty much centered on the mounting flange. If you want I can measure but I think the forward edge of the blades is only an inch forward of the mounting flange face.
#332
#333
Thanks Ross. Ill have to wait until I get my pullies and the radiator I'm gonna use and see what size spacer I will need to mount the fan to.
#334
#335
So i had to get the truck out of the garage again, but this tie i kicked myself out. Moved the truck to the garage at home so its safe and out of the weather. I had planned for a while to do the rear spring hangers and shackles and limited slip clutches in the rear on the dd. Glad i did this now because they wouldnt have last more than a few weeks, and would have broken if i had put a decent load in the bed. I broke the one hanger in half just trying to get the bolt loose with the breaker bar. A drip seemed to start out of nowhere on the rear tank as well as i was working on it so i have to tackle that as well. I think next year im gonna take the bed off and paint the frame because its starting to get pretty bad, especially where the hitch mounts to the frame.
#337
#339
I can take some when i get home tonight. I dont have the floor mounts in yet, but the shoulder mount is just a piece of 3/16 inch plate that i welded a nut to the back of and welded into the channel that goes above and below the rear window.
#342
#343
#344
