Im new here so forgive me if this has been asked. My headlights aren't that bright on my Lariat so I'm thinking about replacing them with after market. What is the best and most popular brand? Thanks
Are you saying that you want to improve the light output by simply changing he bulbs?
If so, then Slyvania Silverstar or Philips X-treme Power bulbs are your best bet for halogens. Upgrading your fogs to a 45 watt bulb instead of the 40 watt stock bulb helps too.
For greater output you can look into HID retrofit kits, like those from DDM Tuning. They really shouldnt be put into a reflector housing like the stock headlamps. They should be installed in a projector housing like those made by Recon Lighting.
