Oxford white code YZ Touch-up what type of paint did ford use?
Old 07-28-2012, 02:20 PM
F2502011's Avatar
F2502011
F2502011 is offline
Wanting to do some touch-up work. A spot repair. The vehicle is a 1996 Ford Truck Oxford White paint code YZ. I know it's a base clear finish but I haven't been able to find out what type (urethane, lacquer, enamel etc.) that ford used at the factory or what would be the best type to buy to do this. I plan to fill in a small ding, prime, paint the spot, then clear the entire panel. Anyone with any info or tips on this please let me know. Have been debating on buying the premixed duplicolor championship white but not sure how close of a match that would be so I plan to go to the auto paint store but I need to know what would be the best type of paint to get to do this and whatever else I may need (reducer, hardner, etc) to most closely duplicate the factory finish. Thanks
Old 07-28-2012, 10:11 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
oem paint is laytex
avoid duplicolor unless you are repairing paint chips/nicks
an auto paint supplier can color match (with a laser or if they are ol timers, by eye) the paint. They can also pre-mix the paint for your gun so minus the hardner, its ready to go- a $ saver. Lacquer is the easiest to use on a small repair but its almost impossible to find....next choice would be Urethane- works & finishes much like lacquer.
1993_f350_2013
05-29-2013 09:29 PM
andyj ford driver
Paint & Bodywork
04-04-2011 08:58 PM
M6EV139445
10-10-2006 04:03 PM
scrape
02-26-2005 09:41 AM
AbadDriver
1978 - 1996 Big Bronco
07-10-2003 11:11 PM
Quick Reply: Oxford white code YZ Touch-up what type of paint did ford use?
