Hard Starting or won't start at all
I own a 1989 E-350, with a 460 fuel injection. The problem I have is at times I go to start it and it will fire off then die. When I go to start it again all it will doo is crank. If I walk away and come back to it about an hour later it will fire right off and keep running. Then at time when I go back to it in an hour it will fire off run for about 15 minutes and then stall out. Totally stumped. I was thinking about changing out the computer if I could locate it. Any suggestions would be greatly appreciated. I tried a search but did not find a similar situation.
PIP failure in the disrbutor will cause similar conditions. Do you get a check engine light when this happsn? if so, do not cut off the ignition, and pull codes.
codes: http://www.troublecodes.net/Ford/eec-iv.shtml
cheap/free way to pull them: http://www.troublecodes.net/Ford/
get a rebuilt distributor at autozone unless u want to tackle the pip sensor urself, not fun,,,you might also have a bad intank fuel pump, not priming the external frame pump, its best u replace both and check for rust in the fuel tanks,, but first before anything u must do a complete tuneup.plugs , wires, dist cap/rotor
pi653
11-12-2016 02:53 PM
Nashterbater
05-30-2016 10:31 AM
StockF150XL
08-06-2010 10:00 AM
