2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
A/C, fan clutch? my numbers are.....
Old 07-20-2012, 12:06 AM
efxengr's Avatar
efxengr
efxengr is offline
07 Expedition w/aux rear air, 172,000 mi, well maintained.
92 deg days in south Florida I'm noticing A/C feels warm at idle but not bad under speed so I took some readings:
Engine off: 90 psi low & high, Amb 84 deg (Gauge Manifold is Mastercool brass)
doors open, a/c on max cool, fan high:
Speed 1500 rpm
Amb. 84F
Low 20psi
High 212psi
Vent Temp 58F
So I added 134a until I got the following:
Speed 1700 rpm
Amb 84F
Low 30 psi
High 275 psi
Vent temp 55F
@idle:
Low 40 psi
High 250 psi
Vent temp 59F
While @ idle or slightly higher I heard the fan clutch kick in (and wind noise), immediately the head pressure dropped to about 190-200psi, low dropped to 30 psi, and vent temp started dropping to 50F and below (48F) but didnt stay more than a few minutes.
Engine off, new high/low pressure is 96F w/ amb of 83F.
At ilde it almost looks slightly over charged. Shouldnt the fan clutch remain on at idle? How can I check or is it better to just replace? Not sure what cycles it, engine coolant temp? refrigerant head pressure? is there a way to test? IT was spinning the whole time while taking readings but there was a noticable change when it kicked in.
Thanks for any thoughts.
Old 07-20-2012, 06:03 AM
critterf1's Avatar
critterf1
critterf1 is offline
Controlled by a thermostat built into the clutch. What engine?
Old 07-20-2012, 06:16 AM
chuck s's Avatar
chuck s
chuck s is offline
'07 Expeditions are all 5.4 V8.
-- Chuck
Old 07-20-2012, 06:25 AM
efxengr's Avatar
efxengr
efxengr is offline
Engine is 5.4L all stock, all original except for one new plug coil, idler pulley, minor misc. A/C control panel was replaced under warranty at 35,000 mi.
Old 07-22-2012, 07:01 AM
slc10844's Avatar
slc10844
slc10844 is offline
Try using a fan to push air accross the condenser to check the pressures. I think the new models use electonically controled fans. My 08 F150 had a pair of wires going to the fan drive. The clutch fan may be doing what it is designed to do.
OPCJeff
15
05-16-2018 11:28 AM
Dhsnnr
05-13-2013 05:27 AM
tjc transport
07-11-2012 04:52 PM
RRE101
09-28-2010 09:18 PM
eds94aero
Aerostar
18
02-12-2005 12:13 PM
Quick Reply: A/C, fan clutch? my numbers are.....
