88 ford bronco fullsize
302 5spd ford bronco. Its in great shape. Im in boonville ny. It was org from texas. Its sat for about 5 yrs till about 2 months ago. And i put about $600 into it with new napa brand parts. I have receipts to prove it. New clutch slave cyl plugs wires cap rotor and ALL fluids have been changed. YES ALL OF THEM. And other little tinkering i have done. Undercoated the frame. Cleaned it inside and out. Did window motor on driverside. And lots of other things i have forgotten about. The bad i need a truck not a bronco. The motor needs a little work high idle and few other things and the worst i lost 5th and reverse gears the other day and i cant figure out whats wrong. I have given up. So my loss is your gain. Overall its a clean solid vehicle just needs a little tlc. And i have about $1200 over all into this truck plus countless hours of my time. So im asking $1500 for it and i have another 5spd from a 95 f150 i will include if i get asking price. Im just not changing it. If your interested hit me up.
sounds like a good bronc, wish you were close to Buffalo. I'm too far west in Ontario to make it worth my trip.
can you post a couple pics here? might help.................
Update
88 bronco needs work. Currently does not run. Fuel pump doesnt come on cant figure out why. It worked fine 2 weeks ago and sat for a week now it wont come on. I had problems with the relay before so im assuming its related. I have $1200 invested in this. Over $600 in new parts my loss is your gain im done messing with this. Would make a great project truck. Truck org came from texas so body is solid. Price is $1100 firm NO NEGOTIATION. You can come come look but if you wont pay that the dont show up. Serious buyers only i have a lot of time and money in this. 302 5spd. It does run pretty good. Just get this thing off my lawn. Call text 315 371 5127 if you cant leave message dont call.
Possible trades for another OBS ford truck can add cash or a honda 400ex atv NOTHING ELSE
The good/new parts
NEW CLUTCH
NEW SLAVE CYL
FRAME AN UNDER BODY UNDERCOATED
ALL FLUIDS FLUSHED AND CHANGED
NEW PLUGS
NEW WIRES
NEW CAP AND ROTOR
NEW REAR MAIN SEAL
NEW U JOINTS IN THE DRIVESHAFTS
NEW EXHAUST THE CAT BACK
NEW AIR FILTER
CHANGED THE DRIVER WINDOW MOTOR
CHANGED BRAKE MASTER CYL
150 miles on all these parts.
I HAVE A SPARE BACK WINDOW
NEW WIPER BLADES
NEW FUEL FILTER
THE BAD
MOTOR LEAKS A LOT OF OIL
NO 5th GEAR OR REVERSE
HIGH IDLE
MAY NEED FAN CLUTCH
TAILGATE NEEDS TO BE REWIRED
AND THE FUEL PUMP PROBLEM
The good/new parts
NEW CLUTCH
NEW SLAVE CYL
NEW PLUGS
NEW WIRES
NEW CAP AND ROTOR
NEW REAR MAIN SEAL
NEW AIR FILTER
NEW WIPER BLADES
NEW FUEL FILTER
THE BAD
HIGH IDLE
MAY NEED FAN CLUTCH
