7.3 - 6.9 starter swap
Old 07-05-2012, 04:59 PM
40dog's Avatar
40dog
40dog is offline
well ive finally got time to get the old 7.3 out of the truck and im looking at a 6.9 to buy . The 6.9 starter is bad and wanted to swap my 7.3 starter in to it to get it running before buying it. So my 7.3 is mated to a t-19 4spd and the 6.9 is mated to a 5sp i believe. will my starter fit to get it cranking.
Old 07-05-2012, 05:51 PM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
it should fit, as the engines are the same. but if you want to be doubly sure, go to a parts store website such as oreillyauto.com, and look up starters for both vehicles. if the part numbers match, that confirms it
Old 07-05-2012, 10:10 PM
tecgod13's Avatar
tecgod13
tecgod13 is offline
It will fit.
It may look a little different, are there are a few different designs for the starters on these trucks, but they are all interchangeable.
Old 07-05-2012, 10:50 PM
oldblue89's Avatar
oldblue89
oldblue89 is offline
You should have no problem. I've swapped starters from my zf5 7.3 to my t19 6.9 before without issue. If you are still concerned the best way to confirm correct fit and operation would be to count the gear teeth on both starters - if they are the same then you are golden. You might see some difference in the body of the starter/nose piece but that won't matter.
Good luck
Old 07-07-2012, 03:05 AM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
I have to say that you guys are wrong, when i swapped the 84 6.9 in....the starter that was in it could not be used. The T-19 has a different flywheel than the ZF-5. It wouldnt work for me for the life of me....i tried and tried and tried...
Old 07-07-2012, 11:16 PM
40dog's Avatar
40dog
40dog is offline
today i swapped the 90 7.3 starter to the 87 6.9 it fit perfectly .the 87 f350 4x4 6.9 has a zf5 and the 90 7.3 was bolted to a t-19 in my 87 f350 4x4. I counted the teeth on the starters they were both 13 .when i removed the 6.9 starter the nose cone was completely broke off and stuck in the bell housing weird. I had to mess and pry with it to get it loose and out of the bell housing.But it worked great and im going to pull the 6.9 engine and prep it for install in my truck this week.
Old 07-08-2012, 02:56 AM
Aune163rd's Avatar
Aune163rd
Mine fit mounting wise....it chewed my ring gear up..
Old 07-08-2012, 09:14 AM
40dog's Avatar
40dog
40dog is offline
well that may be a issue.,between the dualmass and single mass flwheels.But my goal was just to get a engine running before purchase and it did the trick. thanks everyone.
F250KingPin
02-20-2013 10:20 PM
putter5775
09-12-2011 09:36 PM
Royson12
12-04-2007 06:07 PM
BIG R
11-07-2007 04:09 PM
Quick Reply: 7.3 - 6.9 starter swap
