JULY 2012 Tennessee Chat
#32
Until you tell a family "DO NOT use this toilet until it is done..."
And then have to dig UNDER THE HOUSE the next morning....
Been there, and it's why I won't do that anymore
#33
on
CHECK IT OUT!
(Just call me Doctor Dutchenstien)
Ford Truck Enthusiasts Forums - View Single Post - The closest I may ever get to owning a T-bucket Roadster...
IT FIT...
IT FIT...
#34
I was told 12" was wide enough to make it stand up. I think sportsmans would prevent a lot of slippage tho -
And that could make them last longer, even if it
STOOD STRAIGHT UP!
I'm seriously thinking about a HOOSIER street tire like that
Similar to the Mickey Thompson SPORTSMAN, but a harder and better wearing compound
(Something I can get miles out of)
I know, I know - why do I want to drive a "JUMPER" on the street...
If I could tell you - I prolly wouldn't go there, I'd already have the answer
It will also call for extensive bed mods to fit the tires
But if you HAVE just one shot at a dream, and you can DO THAT THING...
Well...
~PICK A DIRECTION~
STOOD STRAIGHT UP!
Well...
~PICK A DIRECTION~
#36
#38
I think I just lucked into that - I noticed myself (and had a few comments by others) that it just had a look all of it's own after the tire and wheel changes I made.
It seemed aggressive, in a way that is hard to fathom but really is there.
It has a strange "PRESENSE"
It looks like more than it is...
It is definitely a "WOLF" truck
#40
I figured a flowmaster exhaust - it won't be quiet. Not by any means!
*Flowmaster builds mufflers that don't muffle - they make the "SOUND RIGHT"
*Did you know that?
373 L/S from an Exploder will be the axle, once I cut off the saddles and weld them in position for the right angle
Explorer axles are bolted from underneath, I can't accept that.
I need to explain that better.
THE AXLE in an Explorer is bolted DOWN.
It is above the leaf springs, so the only thing holding it is the U-BOLTS
For solidity - I want my axle housing UNDER the leaf springs
~It makes it stronger
~Comprende?
*Did you know that?
~Comprende?
#42
