Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #91 (permalink)
Old 07-03-2008, 09:58 AM
Petrol Petrol is offline
Petrol is starting off with a positive reputation.
wow. Someone's been digging through the old threads.
__________________
'99 Expy 5.4L, 2WD,4R100,
List Mod's in Gallery
  #92 (permalink)
Old 07-14-2009, 08:12 PM
2000 22in gator 2000 22in gator is offline
2000 22in gator is starting off with a positive reputation.
my navi is allthe way down in the rear what could this be?
  #93 (permalink)
Old 07-14-2009, 09:47 PM
bnovak bnovak is offline
bnovak is starting off with a positive reputation.
Quote:
Blown or cracked airline, or blown rear bags. Is the pump turning on at all?
__________________
'98 EB Expedition
'08 Mazda MX-5 w/ Cosworth Supercharger
'69 Mach1 Mustang
'40 Chevy Pickup rust bucket project
'79 Wetbike * '94 Waveblaster raceboat
'01 Bluewater Skiboat
  #94 (permalink)
Old 07-14-2009, 09:58 PM
air rride
No the pump will not work.
  #95 (permalink)
Old 07-14-2009, 10:01 PM
Ok probably a blown compressor or compressor relay.
http://www.americanairsuspension.com...NAV%20AREA.htm
Start readin' and let us know what you find (I think there is pump & relay testing somewhere on that page)
Is the check suspension light on?
__________________
'98 EB Expedition
'69 Mach1 Mustang
  #96 (permalink)
Old 07-14-2009, 10:02 PM
Thanks I will let you know...Ed
  #97 (permalink)
Old 08-02-2009, 07:17 PM
tarn tarn is offline
tarn is starting off with a positive reputation.
hi i got a 2006 navigator and i like to lower it can you help me how to adjust the height sensors thxxss sandher21@hotmail.com
  #98 (permalink)
Old 09-09-2009, 09:40 PM
Ducky015 Ducky015 is offline
Ducky015 is starting off with a positive reputation.
Quote:
Originally Posted by BigMattXXL View Post
JACKPOT! - a guinea pig! Have you noticed any difference in the overall quality of the ride after you messed with the sensor? It makes sense that your truck would ride fine, but I'm curious about someone who will move the sensor in order to jack the truck up as far as it will go. I would think that they'd get a lumpy ride...
XXL
CAN I SEE SOME PICTURES?
i wana see how to do it...
i got a 2002 lincoln Navigator and it wud look better if it was lowered
  #99 (permalink)
Old 09-19-2009, 06:55 PM
Red-navi-916's Avatar
Red-navi-916 Red-navi-916 is offline
Red-navi-916 is starting off with a positive reputation.
Hi guys/girls
got a question
is it possible for me to lower the front any? with out taking it to the ford dealer? i know about the sensors and stuff i dont want to touch any of it. my compressor did go out but i got a new one so my car is heatly right now but if anyone knows please let me know on what i have to do..im hoping to lower it a few inches
  #100 (permalink)
Old 10-29-2009, 12:24 PM
spotman spotman is offline
spotman is starting off with a positive reputation.
Anybody know how to adjust the front sensor to get alittle extra lift? The rear was easy but don't see anyway to adjust the front.
Thanks
  #101 (permalink)
Old 10-29-2009, 04:04 PM
Quote:
Thanks
my question also but i want to lower mine
  #102 (permalink)
Old 10-31-2009, 11:30 AM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 is gaining momentum as a positive member of FTE. seventyseven250 is gaining momentum as a positive member of FTE.
I know this is a pretty old thread, but I thought I'd post my question here to keep all the air suspension talk in one place.
The compressor on my Expy is really loud, but it appears to work fine, and I don't think it's leaking from anywhere in the system. Is the only fix for this replacing the compressor or is there some maintenance that can be done to it to quiet it down for a while?
__________________
2000 Expedition
1977 F250
Calgary, Alberta, Canada
  #103 (permalink)
Old 11-01-2009, 09:10 PM
Jimmygunz3 Jimmygunz3 is offline
1999 Ford Expedition
My Garage
Jimmygunz3 is starting off with a positive reputation.
Replace the rubber bushings that are on the bottom of the compressor, they are probably shot
  #104 (permalink)
Old 11-02-2009, 05:27 PM
SoCalFordie SoCalFordie is offline
SoCalFordie is starting off with a positive reputation.
Quote:
SeventySeven, Jimmy is right on to add bushing or some sort of insulator under the compressor. Also, consider replacing the drier unit while you are working on the system. This is a fairly low cost "maintenance" item that will add life to your compressor.
Good luck.
  #105 (permalink)
Old 12-01-2009, 10:30 AM
steve mather steve mather is offline
steve mather is starting off with a positive reputation.
Knealing ?
I am a new owner of a 2002 EP 106k and I notice that occassionally after the truck has been parked the rear end is sagging, this does not happen all the time.... Is this the Knealing feature that is posted? When the ignition switch is turned on the compressor fires up and the height comes back up, compressor turns off. Ride is excellent, I occassionally can hear the compressor turn on while driving. I believe if there was a leak that the compressor would not shut off and the lower action when parked would be constant? Love this truck, thanks for any input
Tags
air , california , expedition , ford , hite , lifted , relay , reset , reseting , ride , sensor , shop , suspension , system , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
