Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-26-2012, 07:54 PM
chamblizi's Avatar
chamblizi chamblizi is offline
1975 Ford Ranchero
chamblizi is starting off with a positive reputation.
Ranchero is fixed :D
I got my truck fixed it costed me 635 dollars though ~,~ i had to take it to a shop for the first time and its my friends shop its been in for about 2 weeks.....
Problems and solutions that solved it all...
1) Timing chain Replaced (Contributed to fixing rough idle) It had the OEM nylon chain kit (Garbage)
2)Carb changed from 4bbl carb back to orginal 2bbl.(Contributed to fixing poor acceleration gauge idle) Too much gas getting dumped into my engine thru the carb/ intake by the 4bbl I new it was oversized when i got it.
3) PCV valve changed due to clogging by rough idle (changed that my self.
4) Distribute Replaced & converted to single Vacuum advance system (Contributed to to removing remaining rough idle to a smooth idle) Someone had putt the wrong distributor on my engine T_T when i got it...
Thanks for all the help everyone.
__________________
"I'll learn my self, where is my beer!"
  #2 (permalink)
Old 07-03-2012, 10:13 PM
burnout400m burnout400m is offline
Garage is empty, add now
burnout400m is starting off with a positive reputation.
Cool. I had a '74 400 that jumped timing. Mine was all stock with a C6 and 3.55:1 (I think that's what it was) and even with the 2bbl carb I put some ricers in their place. I think they're like 500 CFM. It wasn't in good shape but I miss that car.
__________________
I don't collect guns(or vehicles), I accumulate them.
  #3 (permalink)
Old 07-06-2012, 11:23 PM
chamblizi's Avatar
1975 Ford Ranchero
Quote:
right now i just gave her a flush and put in a new rocker arm bolt, reinstalled the rocker and the pushrod i had lose (not in that order).
Only issue left is to solve why i am shifting at 30 then 50..... I think its one of those new vaccum lines he added... something is causing it not to shift properly. It's going to take a bit but at least i can drive it like it is...
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
