03 7.3. No mods,all stock. Ive chekd 4 power at pin 16,cleaned all grounds,pcm swap from another 03. Pcm is of the vdh5 family,still not leting me communicate. Im useing a snap-on modis. Unplugged fuel bowl heater,fuses good,relays good. All the usual test procedure is outta the way. Wicha way now?
When I couldn't connect the cig lighter fuse was blown. Could be a bent pin or bad connection at the plug itself also.(check pin lengths) I take it the scanner works on other vehicles.
Ive checked those pins. Thers power to the lighter
I just bought another computer and my AE would not communicate with the PCM. I forgot to remove the firewall from the computer. After disabling the firewall, all is good.
I live here in B'ham and am always up for making contact with a good resource.
516 31st b-ham. Diesel worx is the name of our shop. Do u need a mechanic? Or help with somthin? dont hesitate to come by or ask man. Thats why im here. My number is 205-675-4617.
Yup,what I got here is a wiring gremlin. I think a ground might be the cause. Ill find it.
I figured this S.O.B figured out. Idm relay clicking rapidly. Ive run into this once before,on a 6.0. Modual to modual communication. Idm was fried. I guess telln the pcm its not grounded. Who the hell knos. Id dig deeper,jus tired of that dam truck. Anyhow,i replaced the idm with the 100 or so I have lyin around the shop and wah lah. Thanx 4 the help guys
