About to throw in the towel
#92
#94
#95
#96
#97
#98
That's a good catch Ilya! Keep us posted when you fire it up.
I'm a little concerned about your rebuilder....I've overhauled/rebuilt a lot of engines over the years....both automotive and aircraft. I always have the shop manual on the bench. All engines are not the same. I usually want to know torque values, piston ring end gaps, valve clearances, and occasionally, how the timing marks are supposed to align. I hate to be a Monday morning quarterback, but in your pic, the marks don't align very well...I would have had to check the manual to see why.
I guess you missed the 4th of July parade this year, but you should be ready for the Christmas parade!!!
Dan
Dan
#100
Yes....usually, on a small block V8, there is a dot stamped on the root of the "V" in one of the gears...and a dot stamped in the tip of the "V" on the other gear...on assembly you align the two dots in a "peak to valley" arrangement. I'd be looking at the book if I found the dots on the peaks of both gears...but then in my younger days I've screwed up this job (just once buy aligning the cam one tooth off) and ended up pulling the engine to fix my error. As I recall it was on a 289 & the timing cover mated to the pan gasket, so it became what I think of as a painful lesson learned.
I admit...the counting links approach is new and different for me!!!
It is cool that Ilya's rebuilder is taking responsibility for the mistake....in the end it looks like things are working out.
#101
#102
Mystery
This is one of the best mysteries that I have read in a long time, lots of unusual characters, a good plot and a happy ending.
Or is it? We still don't know if the thing will actually run. Got to leave something for the sequel I guess.
Seriously, hope it all goes well from here on out; that is one cool little panel.
#103
Glad you found his error Ilya, and sorry it was double the work to get it right. "...never enough time to do it right, but always time to do it over" comes to mind. I love your panel, and hope to see a video when you fire it up.
You'll definitely be driving it again before I ever drive mine.
#104
