Cheap performance upgrades???
Any modifications or extras that I have to get or just plug in and go? Where'd you find a good deal? Summit had them for 55 today
This is the one I am talking about. If you do a search on FTE forums about MSD coils and such there is alot about it not being near as effective without this ignition control.
Digital 6AL Ignition Control - 6425
Obviously any coil will perform better with that MSD 6al box. When using an MSD box on a ford I hardly ever buy a new coil. The MSD box ups the voltage to the coil and turns it from one spark to multiple sparks for the same crank rotation.
Obviously a better coil put in place of a factory coil will perform better. But to optimize performance then yes, the MSD box is needed.
But any aftermarket "booster" ignition system will be great. Jacobs and crane make good ones also.
I'd think you would want wires (ie MSD or Jacobs or Magnecor) made for the higher voltages provided by the aftermarket ignition boxes. Regular carbon wires will wear out quicker. Wires made for the purpose won't break down over time. Wires themselves won't make any more power, the higher quality ones just handle more voltage and last longer. MAGNECOR Race Wires: WELCOME TO MAGNECOR! has some good information on this issue.
I tried out a Jacobs ignition box and ultracoil, got no appreciable mpg gain. I don't know what a dyno would reveal, however. So, I'm back on the factory coil. I'd get an MSD coil if the original one died, it's comparable in price to the oem coil.
But, it's fun to experiment, so go for it.
Apocalypse
02-07-2016 03:58 AM
Apocalypse
1999 to 2016 Super Duty
08-27-2014 07:02 AM
79outlawf150
05-09-2010 10:16 PM
gearhed1971
08-23-2009 09:29 PM
