Cheap performance upgrades???
Old 06-12-2012, 06:36 PM
GLOCKREAPER's Avatar
GLOCKREAPER
GLOCKREAPER is offline
The MSD Blaster coil is one of the best overall mods I've done at any price point.
For under $40 and 5-10 minutes to instal, there is no reason not to get one.
Old 06-12-2012, 07:30 PM
mr.fordneck's Avatar
mr.fordneck
mr.fordneck is offline
Any modifications or extras that I have to get or just plug in and go? Where'd you find a good deal? Summit had them for 55 today
Old 06-12-2012, 07:34 PM
GLOCKREAPER
It's direct drop-in, four screws and two plugs.
O'reilly's has it for $36.99.
Old 06-12-2012, 08:41 PM
Intimnasc's Avatar
Intimnasc
Intimnasc is offline
Are you using the MSD 6A ignition?
Old 06-12-2012, 09:28 PM
mr.fordneck
MSD Ignition Blaster 8227 - Ignition Coil | O'Reilly Auto Parts
This one?
mr.fordneck
I'm not sure but the one we are talking about is the Blaster
Old 06-12-2012, 09:31 PM
GLOCKREAPER
Originally Posted by mr.fordneck
Yes, that's where I bought mine.
Old 06-13-2012, 07:07 AM
Intimnasc's Avatar
Intimnasc
This is the one I am talking about. If you do a search on FTE forums about MSD coils and such there is alot about it not being near as effective without this ignition control.
Digital 6AL Ignition Control - 6425
Old 06-13-2012, 11:22 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Obviously any coil will perform better with that MSD 6al box. When using an MSD box on a ford I hardly ever buy a new coil. The MSD box ups the voltage to the coil and turns it from one spark to multiple sparks for the same crank rotation.
Obviously a better coil put in place of a factory coil will perform better. But to optimize performance then yes, the MSD box is needed.
But any aftermarket "booster" ignition system will be great. Jacobs and crane make good ones also.
Old 06-13-2012, 11:52 AM
Intimnasc's Avatar
Intimnasc
One last question then is would I need the 8.5mm MSD wires or will a good set of replacement motorcraft or Accel wires work? Going from 8mm wires to either the MSD 8.5s or Accel 8.8s more than doubles the price.
Old 06-13-2012, 12:54 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Just a good set of wires is all you need. Make sure they are separated and routed correctly and you'll be fine with 8mm.
Old 06-13-2012, 01:54 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
I used the ford racing wires, they were cheaper them the others and will do the job just fine
  #28
Old 06-13-2012, 02:39 PM
OneTonSoup's Avatar
OneTonSoup
OneTonSoup is offline
I'd think you would want wires (ie MSD or Jacobs or Magnecor) made for the higher voltages provided by the aftermarket ignition boxes. Regular carbon wires will wear out quicker. Wires made for the purpose won't break down over time. Wires themselves won't make any more power, the higher quality ones just handle more voltage and last longer. MAGNECOR Race Wires: WELCOME TO MAGNECOR! has some good information on this issue.
I tried out a Jacobs ignition box and ultracoil, got no appreciable mpg gain. I don't know what a dyno would reveal, however. So, I'm back on the factory coil. I'd get an MSD coil if the original one died, it's comparable in price to the oem coil.
But, it's fun to experiment, so go for it.
Apocalypse
02-07-2016 03:58 AM
Apocalypse
1999 to 2016 Super Duty
08-27-2014 07:02 AM
79outlawf150
05-09-2010 10:16 PM
gearhed1971
08-23-2009 09:29 PM
PaysonPSD
19
01-02-2008 09:23 AM
Quick Reply: Cheap performance upgrades???
