460 Firing Order Diagrams
Could someone email the engine and distributer cap firing order diagrams for the 1996 460. I changed the wires and dist cap and may have futzed it up. Thanks
Jerry
jerdeb@yhti.net
Jerry
jerdeb@yhti.net
The wires can be any where on the distributor.
As long as the rotor points to number where you have number one wire. The engine is numbered..#1 on passenger side front and two than three than four, the drivers side is front five than six than seven than eight. The firing order is usually on intake manifold. if you have a [size=3[vacuum [/size] advance on distributor,it points the direction the distributor shaft will turn.
The Distributor shaft turnsCounter-clockwise
Thats the way you put wires on cap ( firing order).
I hope this helps out a bit.
jodaddy
09-02-2011 04:51 AM
AMISH
12-16-2003 10:56 PM
